Hi,
I have a 98 Liberty Wagon. I noticed that some models of this wagon came with a 12volt power socket in the rear. I am wondering if the wiring would be there already so that if I wanted to install a socket I could wire it into the loom that could be there? The wiring diagram in the manual that I have does not show any of this wiring.
And on a similar train of thought if I were to get hold of the spot/fog lights that fit the front bumper - is the wiring there already and also is the wiring for the switch be in the right location in the dash. I assume I would need to instal a relay.
Cheers in advance
Rear power socket
- stephendean
if your going to install a 12v plug, just install one from the battery with proper wiring and cables, and most factory setups cant handle much, especially if your intending to run fridges etc?
"SUUBMARINE"
20" LED Front Light Bar
