Thought I'd do a small write up, doing a easy task to bleed your brakes...
All you need is -
Pressure Sprayer pump handle type with handle valve from Bunnings $12.95
Pressure Gauge & fittings $13 from Univer
Hose $3 from Clark Rubber.
Assembled and used silicone in most joints, fill up silicone in pressure release valve on the tank or block it, make a hole and place the gauge on the tank to give you an idea how much pressure you have in the tank.
Hose - used original hose to the handle, removed the metal piece (the outlet after the handle) and fitted the hose to the cup (reservoir cup) - got the cup from another Subaru at the wrecker.
All you need is 3 bar approx 45psi to do the job, enough to push the brake fluid out.
Ensure there is no leaks, I checked the joints - spray soapy water and if there is a leak, open it up and use silicone around the leaky joint and allow it to dry, because if there is leaks, its a pain to pump again and again for air losses...
NB - keep your eye on the reservoir till it reaches low level then top it up, use the tap on the handle to close off the air to prevent leakage, if you go below the low level - there is a chance for air to get in the lines, if it does you have to start all over again!
The picture shows it all.
