EJ22 N/A Turbo
Libsta
EJ22 N/A Turbo
Post by Libsta » Wed Jun 09, 2010 6:17 pm
Hey guys... ive been reading a post... http://www.dirtyimpreza.com/forums/show ... 559&page=2
And its about turboing the stock EJ22 n/a motor. Just curious on whether this is possible or not.
By the sounds of what they have done it is... but i mean what is needed besides a healthy ej22 motor :P
I would be only running LOW psi and everything but trying to figure out what exactly i need to do this conversion
Any help would be appreciated :)
cheers
Bob
Post by Gannon » Wed Jun 09, 2010 6:51 pm
There are 3 sides to the modification triangle.
Powerful, Reliable and Cheap
Choose 2.
It could work for a while, it could last for years, but there is a reason that there is a difference between turbo and non turbo engines.
I was considering it, but i wouldnt do it to my daily driver, id only do it in my weekend car.
Libsta
Post by Libsta » Wed Jun 09, 2010 6:58 pm
True true.. thats what im hmmming and ahhhhing about.. whether it will last
My other thing is.. my car is FWD atm.. would i need to convert to AWD or would the box hold for now?
I found a you tube vid of a guy that did one...http://www.youtube.com/watch?v=p1UybkYZOI0
Post by sven '2' » Wed Jun 09, 2010 8:18 pm
Motor sounds pretty good
Like the backing music
but...can't see why one would bother with a NA FWD when gen AUDM and JDM RS's go for around $3-5k with all the goods, or GX/LX conversion can had be for less.
Both with A LOT less stuffing around
But hey, if you do it, be sure to document the project here
Sven
Gleno
Post by Gleno » Wed Jun 09, 2010 9:11 pm
If you went ahead with this project i would definately change the gearbox.
i have an n/a 2wd liberty and i get heaps of slipping of the tyres, would hate to think what it would be like with a more powerful engine.:rolleyes:
cheers
Glen
Post by AndrewT » Wed Jun 09, 2010 9:52 pm
Suparoo wrote:There are 3 sides to the modification triangle.
Chose 2.
Altho really, a conversion to a turbo motor fulfills all three of these :) It can be done cheaply if you can source a well priced frontcut, and it's very straight forward in most cases.
Post by Gannon » Wed Jun 09, 2010 10:32 pm
I was mostly referring to trying to be cheap by turboing a NA motor as opposed to forking out to buy a turbo motor
seagull
Post by seagull » Thu Jun 10, 2010 1:45 am
Geoffs ej22 with a set of turbo pistions made 280 hp at all 4 wheels and is still going strong
Post by Gannon » Thu Jun 10, 2010 6:27 am
There is nothing wrong with the ej22 block, many guys use it for engine builds. Its the high compression pistons that will eventually cause you grief, especially if you try to use the na ecu
Post by AlpineRaven » Thu Jun 10, 2010 8:33 am
There was a long thread about doing up (turbo/boost etc) EJ22/EJ235/EJ25 on RSLC forum.
Post by RSR 555 » Thu Jun 10, 2010 8:55 am
Forced induction (blown or turbo) on a EJ22 high compression is possible, ask Subarino. It would all depend on the amount force you are trying to push into the manifold? On standard compression you could comfortably use 6psi boost and running 98RON fuel. If you're looking to push more than that you'll need to lower the compression ratio. I found using a set of Cometic Head Gaskets from the USA EJ22 SOHC Turbo model works quiet well. With this config and a intercooler (size does matter) will allow you to increase boost to around 10-12psi. If you want more boost than this, I can help you with a set of factory EJ22 Turbo pistons.
Paul
Libsta
Post by Libsta » Thu Jun 10, 2010 4:45 pm
Well all im chasing is probably around 6psi and thats it... So what would i need to achieve this? I can get a hold of some WRX heads and a manifold etc.. what other things do i need to look at?
How much for the turbo pistons Paul?
cheers
Post by RSR 555 » Fri Jun 11, 2010 1:40 am
If 6psi is all you're ever going to push through the manifold then the standard pistons will handle it with 98RON fuel. If you look to use lower RON fuels then you may want to look at putting STi injectors in the manifold. I would recommend you do this anyway :) as you can then run a piggyback EMS to adjust fuel and timing. As for the pistons, I'll send you a PM :)
Paul
Abaddon
Post by Abaddon » Sat Jun 12, 2010 5:43 pm
don't do it.
Post by El_Freddo » Sat Jun 12, 2010 10:01 pm
Abaddon wrote:don't do it.
Care to elaborate?? Its all good to make a statement like this but its even better if you've got some experience to share about it... and I'm keen to hear it as I reckon a 6psi turbo'd EJ22 would be pretty sweet, so long as you don't flog it every day of its turbo life.
Post by steptoe » Sat Jun 12, 2010 11:59 pm
666 yeeaahh...doooo eet 666
You will most likely have to pussy foot it around at take off with just FWD
twilight essentially did same with EA82 mpfi block with turbo or turbo mod heads. Have the advantage of being able to set timing at 10 instead of 20 BTDC to cater for increased compression over normal
