Where's that fuse?
kj0
Where's that fuse?
Post by kj0 » Thu Jun 03, 2010 12:53 pm
Hey guys,
So, I'm trying to disconnect my Fuel Pump in my Impreza GX. I've tried looking for the fuel pump itself, and I can't seem to get to it, and not having the correct manual does not help. So I figured I would go for the fuse. There doesn't seem to be a fuse for the fuel pump.
Does anyone know if it comes under something else in the fuses or how to get to my fuel pump. I have a look and can't get to it from the boot, and the tank seems more under my backseat to footwell,
Post by Gannon » Thu Jun 03, 2010 1:06 pm
The pump is inside the tank
The fuse might be in the fuse box in the engine bay.
You could disconnect the fuel pump relay, its under the steering column, i think it might be a green connector.
What year model is your Impreza?
kj0
Post by kj0 » Thu Jun 03, 2010 2:00 pm
MInes the newer 05 model.
It's not in the fuse box in the engine bay or the fuse box on the left side of the steering Colum, Already checked those two. the workshop manual I keep being suggested to use is for the 06. However, it suggests disconnecting the wires at the fuel pump. So I don't want to get to the fuel pump, except for that bit. I'm assuming the same way I would replace the fuel pump is the same place I could get to the wires. but can't find that place.
78sti
Post by 78sti » Thu Jun 03, 2010 2:28 pm
Try under the rear drivers side seat, there is an access panel there on by outback, not sure if it would be the same on an impreza.
Just unbolt the panel for access and you should be able to unplug the pump.
Post by Gannon » Thu Jun 03, 2010 4:07 pm
Why do you want to disconnect the fuel pump?
kj0
Post by kj0 » Thu Jun 03, 2010 6:42 pm
I want to change the fuel Filter without getting covered in Fuel. I've always done it by disconnecting the fuse and cranking it. In the manual I have, it suggests disconnecting it at the fuel pump. Now, seeing as there is no fuse,I guess I'll have to do that.
Post by Gannon » Thu Jun 03, 2010 7:32 pm
The fuel pump relay appears to be near the blower motor in the passenger side footwell
Unplug it and start the engine as described
fuel relay.JPG (35.29 KiB) Viewed 2080 times
kj0
Post by kj0 » Fri Jun 04, 2010 4:03 pm
Ahh yup, Didn't check over in the passenger side. Cheers mate.
