subaru l series wagon
could any1 tell me what a stock l series is like on the beach, do they have height clearance issues. Thanks
ummm
your on a beach, beachs are flat ride height?? why
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
hmmmm ok yeah i havent seen many like that but yeah
yeah the cars are fine standard
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- l series mad
these one with a ej22 for sale at the moment
he is a forum memeber
stubaru or something
- l series mad
so they did sell the l series with the ea 82 mpfi motor in australia hmmm well could yous guys please help me find a l series wagon with a ea82 mpfi motor or even better ej22 motor manual 1989-1994 since my old one died thanx to some idiot smash into it at 100 kmh
i need a new one i have a budget of $4000
yes they did I have had two.
search gumtree.com.au
- sven '2'
Do not spend $4K on a L-Series.l series mad wrote:i need a new one i have a budget of $4000
Good EFI models are worth $1.5K to $2K max
Think about a Liberty (will do the same if not better off road) unless you are keen on L for whatever reason.
- Brumby Kid
You could buy a decent Brumby for $4,000.
Or a liberty.
What I think you should do is buy an L series ( 1.5 - 2k max)
And then spend the rest on doing it up. Engine mods, lift kit, etc.
Cheers Cam
Or a liberty.
Cheers Cam
- thunder039
- l series mad
- sven '2'
Think you need to work what you want first. EA82MPFI? Converted L?l series mad wrote:ok but i might come across a or yous might across a l series tha has had alot of work done to it like an ej22 conversion or something like tha an thats the reason i might spend $4k on a l series
EJ L Series ~$3K like this
L Series build (car, lift, wheels, engine, clutch, exhaust) will be well north of $4K
That is why the Liberty ~$2K is such value for money - or for another $500 on top of your budget a Foz with more modern cons as mentioned.
This thread may help - 51 posts of decision making...
- l series mad
- l series mad
They're alright for what they are - you have to find one that's been looked after or do some work such as rebuilding the carbie etc.l series mad wrote:oh an the reason i want a l series with a ej22 or ea82 mpfi motor i s cause ive heard tha the ea82 carb motor is pretty gut less motor no power
As for your question about the MPFI - look for the touring wagons - they're the ones that came out with the MPFI EA82.
Really what you're probably better off doing is buying an L series for cheap - then doing an EJ conversion on it by buying a cheap liberty with a good running engine - auto libs usually go for peanuts with gearbox problems or for the simple fact that not many buy the older autos. Then take your time and do the conversion yourself.
If that's not for you just buy a liberty. If you're wanting to do it up for the sand a great combination in my book is a two inch lift kit - full body, not just strut but you can get away with just strut but you'll lose out on some suspension droop - foz box (4.11 diff, 1.477:1 low range [2L models]) and stock foz size tyres. Plenty of lift, stock gearing and plenty of EJ power.
My 5 cents
