Replacing Clutch L series
Heya
Need advice on how hard and how to replace the clutch in my wagon. Is there any tricks i need to know to pull the gearbox out etc.
robo
robo
- Battlewagon
I third that
But seriously it is a lot easier to pull the engine out.. just leave as much connected to the engine as possible and use an engine crane to lift it out. Highly recommend you machine the flywheel before fitting the new clutch.. also buy yourself a new spigot bearing (6201) from your local bearing shop
If you know anyone with a old gearbox pulled apart, grab their input shaft so you can align the clutch perfectly
And don't forget to have plenty drinks ready
Could be a long day
Plus 5 for engine. A trick is to leave the starter motor out and leave the pressure plate 6 X 12mm bolts lose when you put the gearbox and motor back together. Then just do them up throw the starter motor hole. It makes getting the new clutch in the right position a hole lot easier as the clutch plate can move around freely.
"Claudia"
"Claudia"
what clutch are you going to put into it??
standard replacment L or a wrx??
correct me if im wrong but i think they are the same sort of.
thread jack complete
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
WRX use a completely different clutch pressure plate.. the WRX has a pull clutch and the L.Series has a push clutch but the friction disc from a WRX can be used in a L if needed.spike wrote:what clutch are you going to put into it??
Sorry Bennie but see above reply to Spike.. and just for later knowledge, the L.Series 4WD, Liberty and WRX use a 225mm friction disc. L.Series 2WD use the 200mm disc.El_Freddo wrote:Spike, the L and WRX clutches are different sizes... If it were a liberty the WRX clutch would fit.
I'd say he'd be going for a standard L clutch plate and probabily a standard pressure plate. No use beefing that up for a standard EA job!
You are right about no use beefing up the EA clutch if it's used in a standard L. Scott (red rocket) can vouch for that.. he was left without his car for over a week due to having a "heavy duty" pressure plate installed.
haha.. no stress bro.. I've been stuck many a times with trying to work out what's what with clutchesEl_Freddo wrote:My bad - I was going by flywheel size
Bit off the subject (sorry robo) but Bennie can you remember when you fitted your EJ22, did you have to modify all the holes in your EA flywheel or just the ones (I'm thinking 2) that are there for the timing marks? Slightly further apart than the others.
I've got an EJ flywheel in my L series - I re-cased the L series PT4wd gearbox with an EJ front cases. Sorry I'm no help.RSR 555 wrote:Bit off the subject (sorry robo) but Bennie can you remember when you fitted your EJ22, did you have to modify all the holes in your EA flywheel or just the ones (I'm thinking 2) that are there for the timing marks? Slightly further apart than the others.
Alex, Devil Dave and Subafury Matt should be able to answer that question. AFAIK you had to elongate several holes to make them fit.
Cheers Bennie.. I'll ask Davo next time I see himEl_Freddo wrote:I've got an EJ flywheel in my L series - I re-cased the L series PT4wd gearbox with an EJ front cases. Sorry I'm no help.
Yeah thanks roborobo wrote:Heya
its all cool peoples i dont mind the general chat we are always learning it is a public place
robo
Paul
