Gen2 Lib CC wiring diagram
Venom
Post by Venom » Tue Apr 27, 2010 9:12 pm
Hey guys,
I'm trying to help someone change from a console mounted CC on/off main switch to the dash mounted on/off switch. I've found the diagram for the dash mounted switch but i can't find one for the console mounted one, anyone able to help?
Rhys
Post by AlpineRaven » Tue Apr 27, 2010 9:17 pm
what year liberty is it?
the early Gen 2 '94/95 wire is located right side of steering wheel.
Gen 2 Series 2 '96-98 are located under centre console.
Hope that helps.
Post by El_Freddo » Wed Apr 28, 2010 2:08 pm
If you've got the plug from behind the switch you could easily run it to the desired location by cutting the plug and adding a lenght of wire to the plug/switch...
Venom
Post by Venom » Wed Apr 28, 2010 2:23 pm
Thanks bennine but i already have the plug and the the wiring diagram for the dash mounted switch. What i need is the wiring diagram for the console mounted switch because the wires are different colours. Gen1s have the console mounted switch too but the WSM diagram is just that, diagramatic, and doesn't have individual wires and colours.
Rhys
