Int wipers fitment
phantomD
Int wipers fitment
Post by phantomD » Sun Apr 11, 2010 7:29 pm
Hi all,
I have an int wiper switch setup (from a sedan) ready to go into my Brumby. How easy is it to install this switch, and what is involved?
I am wondering whether I should do it myself or get somebody to put it in.
Thanks in advance.
Post by steptoe » Sun Apr 11, 2010 10:22 pm
Gees, if you got time search under me and electrical, think it was degenearte or gtcompletepower knows how this is done, said to be a blue connector behind the parts binnacle below vent to 'just' hok up and with correct switch. I have same job to do....
preno
Post by preno » Sun Apr 11, 2010 11:13 pm
you will also need the wiper relay located under the dash in the sedan, should just plug straight into the brumby wiring.
matt
Post by El_Freddo » Mon Apr 12, 2010 9:25 pm
To fit the switch you'll need to remove the dash facia - carefully. Swap the switches out and the desired switch will fit in its place. Re-install the facia.
dfoyl
Post by dfoyl » Mon Apr 12, 2010 9:39 pm
Bit more detail for you - yes, you need the wiper `can' as preno referenced. When I fitted to my Brumby (89 model) under the dash (take off the plastic panel that runs under the steering wheel, it has about 3-4 screws holding it and a plastic tab at the back (towards front of vehicle), there was a PINK plastic plug of about 6 terminals of which only 2 were wired (as a loop). Remove this pink plug and insert the wiper `can' into the mating plug. To remove the switch, pull the existing switch cover HARD away from the steering column. Undo the nut with a shifter, and you should be able to pull the existing plug out from underneath. Switch in your ex-sedan switch, push back into place, re-tighten nut, and then press the new switch cover firmly onto the switch shaft.
Test the wiper switch by turning ignition to ACC (quite possible your wiper `can' is faulty), if ok re-attach underdash cover and you're done.
Dean.
