EA81 to an EA82 MPFI
- brumbybear
hi guys how much stuffing around and modifying would there be if i went from an EA81 to an EA82 mpfi in my brumby?? any suggestions and tips on what might need doing??
Cheers Lasty
Cheers Lasty
Im looking for a cheap second hand 2-4" lift kit for my brumby... if u have one pm me plz
Hey mate, Best idea would be to go an EJ engine. With the amount of wiring adn stuff you have to to and the power increase, its easier and more benifical to EJ it.
And i prefer the ea81 over the 82 as well, stronger motor and wont die!
- brumbybear
yeah i thought about an ej20 or an ej22 maybe even turbo ...... but funds are low at the moment and im just getting ideas at the moment for when the cash is available.... But i gotta lift the beast first but even lift kits are bloody dear.....
It has been done before so I'm sure there is someone out there that can help but it's not me
but I can tell you that the EA82 is a lot wider than the EA81 and it comes very close to the chassis rails. Because of this I'd also recommend you use an EJ series engine because you'll need to do just as much work (wiring and fuel setup) as you would fitting the EA82 EFI model. The EJ is also a lot more reliable than the EA82.
You should be able to find a EJ22 for almost the same price as the EA82 EFIbrumbybear wrote:yeah i thought about an ej20 or an ej22 maybe even turbo ...... but funds are low at the moment and im just getting ideas at the moment for when the cash is available.... But i gotta lift the beast first but even lift kits are bloody dear.....
Also with regards to the lift kit, also look for someone or wreckers that have a lift kit in the MY (EA81) wagons as they are the same as the Brumby
- brumbybear
- brumbybear
