your EJ and where to get it??
can we have some input from the smart people here??
toonga, andrew, step toe im looking at you
i propose a list..... (a list they all whisper lol)
perhaps we should include
power, aspiration and what models they came in??
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- TOONGA
why do people think I'm smart
I'm just a grunt but heres a start from the nice people at wikipedia
http://en.wikipedia.org/wiki/Subaru (models and makes)
http://en.wikipedia.org/wiki/List_of_Subaru_engines (engines-general)
http://en.wikipedia.org/wiki/List_of_Su ... nsmissions (transmissions -general)
http://en.wikipedia.org/wiki/Subaru_EA_engine (ea engine)
http://en.wikipedia.org/wiki/Subaru_EF_engine (ef engine)
http://en.wikipedia.org/wiki/Subaru_EJ_engine (ej engine)
just a bit of light reading
Hmm.. what are your plans to do???
There are EJ engines and your better off getting Gen 2 EJ22 over Gen 1, but again not much difference because they're widely available, EJ20 is slightly harder than EJ22.... Depends what wrecker you go to and your friends with them etc then you can score yourself a good deal..
I got my latest one as a half cut BG5 from ichibahn.
EJ20h tt
These motors have better flowing heads and cams then the stock wrx ones
being JDM model it had 206kw in twin turbo
Converted it to single turbo td05g with extractors.
Will be putting a front mount IC
then getting it tuned. Only has the stock WAIC so i can only run about 12psi with out inlet temps going through the roof.
I ended up using the RS liberty intake (slightly shorter in height so did not have to space cross member) and loom to integrate into existing conversion.
EJ20h tt
So many optioins not enough time or money
i havent got plans at the moment
toonga was on the right track.
just a post maybe make it sticky. to tell people the engine they want and where they can get it.
if you want major power you could look up and find a EJ20TT and then go yep i need to find a liberty rs or whatever to get the engine
GETDIRTYCLOTHING
GETDIRTYCLOTHING
I got my EJ22 from a liberty at Pick a Part. Half price too...
Generally:
Impreza = EJ20
Impreza WRX = EJ20 turbo
Liberty = EJ22
Outback = EJ20 (?) EJ25
Forester = EJ20, EJ25
Hope that helps. Someone correct me if I'm wrong as I'm only going by what I've read on the forum and seen on the street.
Generally:
Impreza = EJ20
Liberty = EJ22
El_Freddo wrote:I got my EJ22 from a liberty at Pick a Part. Half price too...
Generally:
Impreza = EJ20
Liberty = EJ22
Outback only had EJ25 and EZ30.
yes this is what im getting at..........
any moderators reading this perhaps it should be made sticky?
or a better cleaned up version??
GETDIRTYCLOTHING
GETDIRTYCLOTHING
ummmm sea gull this isnt actually a place to buy or sell, just to work out what car you should be looking out for
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- vincentvega
oh yes im not saying that it was wrong for seagull to post here i just beilve that this is the wrong thread to put it, if your not a member than simply make a new post and not hyjack a thread..............
GETDIRTYCLOTHING
GETDIRTYCLOTHING
