inspecting brumby what too look for?
spidersubaru
Post by spidersubaru » Mon Feb 22, 2010 10:21 pm
Hi i am about to go an inspect 92 brumby for possible purchase what are a few things which i should be on the lookout for? :)
nncoolg
Post by nncoolg » Mon Feb 22, 2010 10:38 pm
...a WRX engine :)
# EA82 AWD 4EAT,
Post by TOONGA » Mon Feb 22, 2010 11:01 pm
rust around the windscreen, in the sills, the guard flares, rust/bog in the tailgate, in the floorpan on the driver side, the towing points at the front, the radiator support where the sump protector bolts on , beneath the tailgate, the bottoms of the doors, at the point where the cab meets the tray where the bung holes to let water out are, these are the most likely places for rust
check the cv's front and rear and the hubs if possible
take it for a drive out on the open road and listen for wheelbearing noises and feel for vibration through the steering
check the brakes (rear for leaking slaves) front for sticking calipers
check for leaking front struts bottom ball joints
I could go on but if the owner has cared for the car then most of this won't be a problem
spidersubaru
Post by spidersubaru » Tue Feb 23, 2010 7:01 pm
thanks for the input, that sounds good on the rust side of things what about the engine? any couple of major things to look for?
Post by TOONGA » Tue Feb 23, 2010 11:05 pm
nncoolg wrote:...a WRX engine :)
that would be nice hehe
noisy lifters, blow by from the oil filler tube, excessive oil in the air cleaner, clutch play, leaks in the master cylinder
