were is fuel relay
were is fuel relay
Iam trying to find my fuel pump relay on my on my 89 l wagon, fuel pump not get power, fuse's are all good so must be relay i think. Help i cant find it and what does it look like is it one of the round one's?.
[SIGPIC][/SIGPIC]1991 L series touring wagon, ea82t,tdo4,tmic,vl 380cc injectors,adjustable fuel pressure regulator,pod,5 speed rs turbo awd gear box,lsd diff,3 inch zorst to big ass cannon ect.. my baby
There are 4 round relays mounted together near the ECU, the fuel pump relay should be one of these.
You do know that the fuel pump only has power for 2 seconds after the ignition is switched to on. It only comes back on if the engine starts.
If you join the 2 green test connectors together, the fuel pump should cycle on and off with the ignition on at a ratio of 1 second on, 1 second off.
