98 ej20 AWD Auto ECU wiring diagrams
Hi guys, I'm chasing the ecu wiring diagram to suit the 98 Subaru Impreza AWD auto EJ20. It has a single plug into the ecu held in with a 10mm bolt. Thanks
Are you sure???drof351 wrote:It has a single plug into the ecu held in with a 10mm bolt.
Sounds to me more like the SMJ (super multiple junction)
Its a large connector that joins the engine wiring with the bulkhead (underdash) wiring.
Most ECU's had 3 plugs
Post up a pic.
There are 2 files here that you can download (173mb total)
PDF-Subaru-Impreza-1997-1998-Service-Manual.html
Here you go, The "ECU" and wiring are just resting on the engine until I can finish finding all the wires. The car is running and driving, auto is changing etc. Just want to find the temp gauge wire, tacho, oil light, pedal switch, power button etc
- 102_3076.jpg (113.86 KiB) Viewed 5210 times
I can t seem to get this to work? Do you think its the right one?Suparoo wrote:Post up a pic.
I might be able to help... can u remove that white plastic cover off the ECU plug there?
Is the car running and mobile?? Where are u located... im 20mins north of Perth.... if your able to bring it over sometime i can definately help.
I have done heaps of these and never seen a ECU plug bolt on like that or have that cover. Im wondering if the bolt is just for the cover or to hold the plug in.
Temp and oil don't come out of the ECU they come directly from the motor so an ECU diagram wont help with that but i could be some assistance in locating them for u.
Dave
Dave
Ohh... and PM me if i don't reply on here... i lose posts sometimes and im not on here often.
Dave
Dave
- vincentvega
No its not, the TCU and ECU are separate. Newer cars with CAN-Bus systems may be different.vincentvega wrote:97 on is an integrated ECU / TCU. all done in the one unit
The ECU is usually located in front of the passenger footwell and the TCU is up beside the steering column.
Id say from the airbox is more likely from a 2007 onwards, which may explain the single plug ECU that we have never seen before
Jeff
- vincentvega
mate I have an integrated TCU / ECU sitting on my desk. dont tell me they dont exist.Suparoo wrote:No its not, the TCU and ECU are separate. Newer cars with CAN-Bus systems may be different.
On some models this is true. on others its not.The ECU is usually located in front of the passenger footwell and the TCU is up beside the steering column.
Don't assume just because you know something about a particular model that it applies to all cars.
Looks as though i may have been wrong
I know 1998-2003 Liberty's are separate, 1989 to 1993 liberty's are separate and the 2002 Impreza's is separate, so yes i assumed that all others must follow suit.
So what cars came with the intergrated ECU/TCU?
- vincentvega
