Colder, big bore thermostat - runs cooler
TT2041 - 170 is the tridon brand part number of the colder than std 180 deg F thermostat I fitted up today in about ten minutes, into my EA82T L Sedan.
It is the same as what DiscoAdrian has used in his EA82T. Ten deg F cooler opening and bigger bore - although they may not open as far as the std 180 std bore thermostats. They are about twice the price of a standard but worth it in my opinion in the warmer climates of our continent.
Using my engine watchdog digital temp readout of the engine METAL, not water, I am seeing the expected difference of about 6 deg C. The dash gauge also shows a slight reduction in the operating temp.
For a warmer heater in winter I am sure I will be using a standard thermostat again come Anzac Day
Next tinker will be add a thermostat device to keep my LPG converter at about 130 - 140 F (54 -60 C) the optimum temp for vapour conversion to avoid heavy ends in the liquid gas falling out of suspension. After that the water wetter stuff....
- discopotato03
Yes I like those thermostats in EA82T's , I think the advantage is that they can open up a large area fairly qickly which seems to suit the rapid changes in coolant temperature in these flat fours . Provided you have the ability to drag enough air throught the radiator you can keep the temp rise in check by pulling a lot of heat out reasonably quickly . I do it with the std viscous hub fan and a Davies Craig bulb type elec fan switch to operate the condenser fan . Bulb is in the radiator end of the top hose because it always had chronic leaks when at the thermostat housing end of this hose .
My car warms up reasonably quickly from cold and I don't think 76c is too low in winter . I run synthetic oil so it doesn't need much if any innitial heat to be quite fluid at cold temps , mineral oils are different particularly the 20Wxx ones . Factory reckons 15Wxx for Australian conditions but thats another story .
Cheers A .
Cheers A .
- T'subaru
Sounds trick, sorry to sidetrack post. would you post up a pic sometime?steptoe wrote:Yeah, IMPCO L converter feeding an IMPCO 200 mixer in a dedicated config, bypassing the early flapper style afm entirely. I have air filter box sitting in spare wheel well feeding to mixer then through turbo - love it!
ive got the part number written down and will be ordering 2 in tommorow.
driving home today temp guage was fine got up the drivway came high but not red then suddenly steam in the cockpit, as i threw mum out the door thinking it was smoke.
well apparently the heater cores gone but still im sick of it over heating.
if im needed for anything spike.pickstock.racing@hotmail.com and ill try and get back to you.
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- Mr Top Hat
steptoe wrote:TT2041 - 170 is the tridon brand part number of the colder than std 180 deg F thermostat I fitted up today in about ten minutes, into my EA82T L Sedan.
can this thermostat be used in a EA82 carbie ?
1990 L series wagon Ej22
i didn't realize this image was so large :-O
it is a listing for ea81 and ea 82 not just the ea82T, so I'd say yes it will fit your EA82 carby manifold thermostat housing. It is both a colder opening thermostat by the 170 F instead of 180F (about 6 deg C difference) and a bigger opening. You can just get a colder std opening thermostat to try but why not go the whole hog.... like we have.....
Guys just remember, these aftermarket 'TTS' or 'Sports' thermostats are only the same size as the genuine subaru ones anyway, so if you are going to use generic thermostats you should always use these 'sports' (OEM subaru size) ones, the normal generic ones are way smaller that OEM. The benefit of the tridon catalouge is of course the above mentioned colder ones. You can also get a cooler fan switch to match.
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
