Fitting TD04 to EA82T
H-top
Post by H-top » Sat Dec 26, 2009 10:41 pm
With regards to water an oil lines, what mods are required to fit the turbo?
Cheers sam
H-Top
rolling in
Post by Gannon » Sat Dec 26, 2009 11:07 pm
Bugger all
The oil lines are the same, the water supply from the head is the same and the water return just has to go over the compressor outlet
I'll see if i can dig up some pics
H-top
Post by H-top » Sun Dec 27, 2009 12:11 pm
Fantastic, that would be great!
H-Top
rolling in
H-top
Post by H-top » Mon Dec 28, 2009 11:43 am
Find any pics?
cheers
sam
H-Top
rolling in
Post by Gannon » Mon Dec 28, 2009 12:15 pm
In this pic, you can see the water line (1/2 inch rubber heater hose) underneath the BOV
Here is another
Keep in mind that this setup is not ideal as an airlock can form and prevent convection of the water through the turbo after the engine is shut down.
Ideally, the water line should come straight out towards the tranny bellhousing and then underneath the compressor outlet. This will maintain a relatively straight path back to the thermostat
