Outback Front Suspension
My 97 Outback is starting to feel a bit worse for wear over the last year or so and I've decided to take care of a few issues that probably need some attention. Biggest concern is a noise in the font suspension best described as a bump or clunking kind of sound when you move over say a small pot hole or bump in the road. Intend to take the car to a suspension expert this week but thought I'd pick a few brains to see what responses I get to compare with the suspension shops verdict. So what might the most likely cause be if you've experienced something similar with your vehicle at some time in the past?
- bobbyjimmy
Common problem with high mileage subaru is the rear control arm bushes, mine is making creaking/knocking noises, it has new suspensions fitted but the noises is still there. Costs $145 each after market.
