EJ20 & EJ22 Engine Builds
dadcanyou?
Post by dadcanyou? » Sun Dec 13, 2009 3:56 pm
I am attempting to find out the following
1. Are the crankshafts and rods in an EJ20 & EJ22 the same?
2. If the above is YES can the EJ22 crank,rods & block (using aftermarket pistons) be used to build up a 2.2lt Turbo Engine.
mattl200
Post by mattl200 » Mon Dec 14, 2009 9:34 pm
as far as im aware the only diferance on the bottom end of the ej20 /22 engines is the piston size
apart from the ej20 being closed deck in some cases
Post by AlpineRaven » Tue Dec 15, 2009 6:37 am
I think from back of my head, the crankshaft is the same but pistons are different.
I know that EJ25's crank is different again, if you put EJ25 in EJ22 it'll become EJ235 (2.35litre)
Post by El_Freddo » Sat Dec 19, 2009 7:07 am
Yeah as they've said above - I don't think the bottom end is beefier in the EJ22 over the EJ20. Cheapest way to go is to get a turbo half cut. Or try and get a turbo EJ22 block from the US, they got them in the legacy over there from what I've read.
phillatdarwin
Post by phillatdarwin » Sun Dec 20, 2009 10:35 am
from what i have read it is the rod and piston are not the same but this is just what i have read on the net .
Google it and find out
