warning lights in dash
imartin
Post by imartin » Thu Nov 26, 2009 7:21 am
yesterday i started my gen1 liberty, at about 330 in the arvo it had been sitting in very very very hot sun all day, i drove it for probably 10 or so k's and then turned it off and went inside, i came back out an hour later and started it up and the battery indicatior and the park brake indicatior and the exclamation mark ((!)) were all on i'm thinking its just a wiring problem maybe caused due to the heat, can anybody confirm this or say what it might be?
thankyou
lunatech
Post by lunatech » Thu Nov 26, 2009 4:17 pm
I've had this happen, minus the hot day, because of the alternator not charging. Hope this helps.
Robert
Red 1990 Legacy L sedan 5MT at least 292000 mi.
Thalass
Post by Thalass » Thu Nov 26, 2009 5:32 pm
If it gets really hot, a battery can have a higher self discharge rate (wheras a cold battery will hold less charge overall, but lose it at a lower rate - or something like that). So that, coupled with a short drive that probably wouldn't have replaced the power used to start the engine, might have the battery low enough to have lights come on.
Having said that, I'd check the alternator first. And the battery water, too.
Post by El_Freddo » Sun Nov 29, 2009 7:57 pm
This happened to me when my L's alternator died...
