bigger ea82 radiator?
nncoolg
Post by nncoolg » Fri Nov 06, 2009 5:43 am
I have heard a whisper that a 2 row radiator is available for the L series? Im not sure how, is this true?
# EA82 AWD 4EAT,
Post by steptoe » Fri Nov 06, 2009 8:06 am
if you not got AC and wanna try a budget double core, use an AC condensor in its usual place but plumb it up to water. A boundary rider in here years ago did this with great results.
discopotato03
Post by discopotato03 » Fri Nov 06, 2009 12:55 pm
I do sometimes read about twin row L radiators at USMB , I think they may have been aimed at auto turbo cars .
I personally think an oil cooler with the thermostat in the oil filter adapter is a better bet . Engine oil usually runs hotter than the coolant temperature so the difference in temperature between air and oil means good heat rejection .
There is one golden rule , NEVER use 2nd hand oil coolers because they often come off blown engines and had crunchy bits go through them . It is impossible to get it all out but if some does its going through your engines oiling system - expensive .
A .
RX Coupe
Post by RX Coupe » Sun Nov 08, 2009 9:48 pm
I had a custom brass tank two core radiator made up for my old L series wagon when I had it. It took it out to use in the RX coupe but never fitted it. In the old L series it did make a huge difference on cooling on a hot day.
Cars: 02 Subaru Outback
85 Subaru RX Turbo Coupe (sold)
92 Subaru Brumby (sold)
