02/lambda sensors
chubby37
02/lambda sensors
Post by chubby37 » Wed Nov 04, 2009 2:08 pm
is there any differance between the sensor in a EJ22 and a EJ20T????i need to put back the 02 sensor behind the turbo that someone took out and i,m not sure if they are all the same or not
tex
Post by tex » Wed Nov 04, 2009 2:33 pm
Try going to your local parts interpreter and check out the parts numbers Because i know some of my stuff wasn't compatible but they should be fairly similar but then the heat range would'nt surprise me if its diffetnent!
87 targa brumby (Neglected),
+ others.
chubby37
Post by chubby37 » Wed Nov 04, 2009 3:03 pm
oh ok...cheers
Post by Gannon » Wed Nov 04, 2009 4:09 pm
Yeah should be the same
