Black smoke from exhaust & hunting...
shadyhaze86
Post by shadyhaze86 » Thu Oct 29, 2009 9:33 pm
hey guys, i have a 99 wrx.
Started out that i had a hesitation/miss on acceleration,checked for vacuum leaks, theyre ok.
I cleaned out the AFM and now the hesitation is gone but its now blowing black smoke out of the exhaust and the engine is hunting at idle.
Any ideas on wats going on would be muchly appreciated, cheers :)
someguy
Post by someguy » Thu Oct 29, 2009 9:54 pm
Maybe a blown head gasket?
Smoke is a bad sign :(
Outback bloke
Post by Outback bloke » Thu Oct 29, 2009 10:05 pm
Black smoke is to much fuel. Hunting at idle I normally associated with an air leak which is generally a faulty BOV. However with you cleaning the maf it may have left a residue on the sensor. Is it a hotwire or pad model air flow in yours?
Captain Obvious
Post by Captain Obvious » Fri Oct 30, 2009 5:41 am
what OB said, i use contact cleaner to clean my afm, leave no residue. also it maybe worth running a can of subaru upper engine cleaner through the IACV (idle Air Control Valve) system, as the IACV could be dirty and causing the hunting?..
bryan
ps the IACV is on the pass side of the car on the back of the manifold and is a creamy color.
Post by steptoe » Fri Oct 30, 2009 7:56 am
it is the O2 sensor that trims fuel. If it is no longer working or connected ECU just goes max rich making black exhaust smoke.
shadyhaze86
Post by shadyhaze86 » Fri Oct 30, 2009 8:25 pm
Thanks for the ideas guys, will get back to u when i try a few things :D
Post by AlpineRaven » Fri Oct 30, 2009 8:49 pm
Or oil leak burning off in turbo area? or back pressure from the engine into turbo?
