cv boots
chubby37
cv boots
Post by chubby37 » Wed Oct 21, 2009 9:55 am
found these guys while doing some looking around on the net
http://www.cvboots.com.au/
justincase41
Post by justincase41 » Wed Oct 21, 2009 11:37 am
Emailed them about prices late september and got this reply,
"Pop Ri not currently available in Australia, have got Mega Pop and Car X, suggest you measure shaft size and max joint diameter for suitability".
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
chubby37
Post by chubby37 » Wed Oct 21, 2009 12:07 pm
oh ok..they replied to me with this yesterday
To the best of my abililty I have deduced that the cv boots you require are of shaft size diam 24.5mm and cv joint diam 85mm. The choice is quite wide on your make and model. The Car x cv boot would fit this very well, and up to 88mm max joint size.
Price of each Carx kit is $15.00
Fitting Cone is $12.00
Strap Tool is $15.00
Postage is likely to be $10.00 plus $2.80 insurance.
I hope this helps. Confirmation of shaft and cv joint sizes would be appreciated before ordering.
subybrumby
Post by subybrumby » Wed Oct 21, 2009 4:29 pm
I bought his mega pop boot and tool. The boot is very large and stepped. You just trim off what you don't want.
subybrumby
Post by subybrumby » Wed Oct 21, 2009 4:35 pm
Looks like this
[ATTACH]1674[/ATTACH]
[ATTACH]1675[/ATTACH]
[ATTACH]1673[/ATTACH]
chubby37
Post by chubby37 » Wed Oct 21, 2009 5:12 pm
be cool to see them..i placed my order today.i liked the cone that you can buy too...i ordered the strap tool from them to be able to use the metal strap that comes with the kit...bout time i stopped using zippy ties
subybrumby
Post by subybrumby » Wed Oct 21, 2009 7:49 pm
I bought the tool too..Makes it a lot easier. The megapop boot didn't last but it was not its fault. The boot looks the goods and I'd be interested to know how they last under normal conditions.
Mine exploded because it was rubbing on the extension of the steering column lift kit and was attacked by the heat from an unshielded turbo. I changed the whole front back to normal brumby setup and included two new complete axles in the exercise.
The megapop boot as you see, secures the small end, then it steps up. find the section that is your size for the big end, secure with strap then trim. Its pretty easy and looks ok.
With regards to the straps, I went into a local CV joint here and bought a big handful of the straps for $20.00.
phillatdarwin
Post by phillatdarwin » Wed Oct 21, 2009 8:17 pm
i do not like them as it looks like the boot is pulled to tight .
and if it is too tight, it will split very fast .
not enough ribs in it to stretch.
