Has anyone used Nissan 280ZXT injectors in EA82T ?
discopotato03
Post by discopotato03 » Sun Sep 13, 2009 10:17 am
Hi all , the Americans seem to think that Nissan 280ZX Turbo injectors have been used in EA82T engines - sometimes with no other mods other than rubber hose tail conversion .
I think they are around 10% higher flow rate and the std computer systems can probably about cope with that .
Cheers A .
Post by Subafury » Sun Sep 13, 2009 7:48 pm
dont quote me on this but i seem to remember 240sx were the same too. i was thinking about doing this at one point. cant really offer any more info tho sorry.
Post by Gannon » Sun Sep 13, 2009 8:21 pm
I was in a workshop at one stage and the injectors on an RB30 (VL Commodore) looked very similar to our EA82 injectors.
discopotato03
Post by discopotato03 » Mon Sep 14, 2009 1:56 am
I was just curious to know if anyone had tried the slightly larger injectors in an electrically std EA82T engine .
There are a few types of hose tail injectors around but I think modifying the more common 11mm "O" ring style injector would open up more options .
Haven't tried yet but I think machining barbs into the top section to make it effectively a hose tail style injector would be quite simple .
I found a set of 91 Magna 2.6 injectors and I need to find out what their flow rate is , they may not be suitable . Just wanted some O ring injectors to play with .
Cheers A .
Post by Gannon » Mon Sep 14, 2009 6:10 am
On the USMB, a member called 'Preslab' did some electrical modifications to his EA82T ECU
I can shoot you his email address if you like,.. PM me
