Home made lift kit?
kona480
Home made lift kit?
Post by kona480 » Fri Sep 04, 2009 7:14 pm
Hi
I was talking to my teacher (who also has a brumby) and he said for about $50 for materials, I could make a lift kit at school. i was wondering if this was a good idea and how much it would cost to get the brake line and steering shaft extensions? Also what about insurance as I am a P plater?
thanks
phillatdarwin
Post by phillatdarwin » Fri Sep 04, 2009 8:20 pm
u can get brake lines made up for about $100 for rubber or s/s brade to adr for about $180 . as for the lift kit go for it and make one as if u know how to weld and drill holes procice it wood not be hard for u .
and if u look on hear u can find lots if u can not find it PM me and i will send u what i have found on the http://WWW.com
GOD
Post by GOD » Fri Sep 04, 2009 10:15 pm
Some of this might be of interest: showthread.php?t=12394
Dane.
Post by TOONGA » Sat Sep 05, 2009 12:48 am
there are these threads
showthread.php?t=14743
showthread.php?t=14590
which should give you an idea of what you need and how much work is involved
Outback bloke
Post by Outback bloke » Sat Sep 05, 2009 5:43 am
Did your teacher factor in the cost of bolts? It doesn't seem like it as they will cost you more than $50
Post by AlpineRaven » Sat Sep 05, 2009 10:34 pm
what kind of materials? that sounds too cheap!
kona480
Post by kona480 » Sun Sep 06, 2009 7:29 pm
I'm not sure, nothing is official, just talking about the idea at the moment
Outback bloke
Post by Outback bloke » Sun Sep 06, 2009 8:20 pm
I say go for it. It will be interesting for you. We are just saying that we think it will cost more than $50, that's all.
phillatdarwin
Post by phillatdarwin » Sun Sep 06, 2009 8:24 pm
i have price one out a ally and it will cost around $200 just for the ally box and that is not with any cost of welding on it as well .
kona480
Post by kona480 » Sun Sep 06, 2009 9:48 pm
phillatdarwin wrote:i have price one out a ally and it will cost around $200 just for the ally box and that is not with any cost of welding on it as well .
what do you mean the ally box?
Post by AlpineRaven » Sun Sep 06, 2009 10:15 pm
kona480 wrote:what do you mean the ally box?
he means - Aluminum block.
Post by El_Freddo » Sun Sep 06, 2009 11:03 pm
What you'll be after is the steel box with crush tube welded inside the box. Crush tube is basically steel tubing that takes the load of the torqued bolts so the box steel won't crush in on itself.
With ally block its pretty easy to make a lift - just cut the block to the right length for each block and drill the holes required...
The trickiest bit will be the strut towers - you'll need to offset them an appropriate amount to fix the camber. Some one will know the correct offset to use - I planned on making my lift but it hasn't happened yet... Time will tell.
All the best with it, you'll love it once you fit it to your subi!
