Looking for EJ D\R
U.SBoy8706
Looking for EJ D\R
Post by U.SBoy8706 » Tue Jul 21, 2009 10:17 am
Hello everyone my name is Drue and im a new member to the forums, Im trying to find a 5 speed EJ Dual Range transmission and have it ship to the U.S. If anyone point me in the right direction as to where i might be able to find a shop, private seller, or other second party that would be willing to ship to the U.S it would be greatly appreciated.
Thanks everyone,
Drue
Post by AndrewT » Tue Jul 21, 2009 10:22 am
"Christian" on this forum has one forsale I think, not sure if he'd want to send it to the US though.
Otherwise try posting up on the USMB forum which is US based - http://www.ultimatesubaru.org/forum/index.php?
U.SBoy8706
Post by U.SBoy8706 » Tue Jul 21, 2009 11:55 am
AndrewT wrote:"Christian" on this forum has one forsale I think, not sure if he'd want to send it to the US though.
Thanks Andrew for the advise, I've already been on the USMB boards for quite some time actually. As it turns out there is only one person on the board that has this trans and he believes he is the only one in the US. Ill get in contact with Christian if he would be willing to ship to the us I would make it worth wild.
Thanks
Drue
Post by guyph_01 » Tue Jul 21, 2009 6:21 pm
i have an ej dual range 5 sp box
It was in a front accident car, i was not able to drive the car for long but it went in all the gears. I want $450 for it.
Post by AlpineRaven » Tue Jul 21, 2009 9:47 pm
I would advise to do homework first and how much it'll cost you to export to US - wont be cheap.
U.SBoy8706
Post by U.SBoy8706 » Wed Jul 22, 2009 1:08 am
guyph_01 wrote:i have an ej dual range 5 sp box
Would the box bolt up to my EJ 5sp trans out of my 94 imp L? Also would you be willing to export to the U.S?
U.SBoy8706
Post by U.SBoy8706 » Wed Jul 22, 2009 1:12 am
AlpineRaven wrote:I would advise to do homework first and how much it'll cost you to export to US - wont be cheap.
Thanks for the advice Alpine im aware that it wont be cheap to export but im willing to pay. I guess i need to check around to find what it should cost so i dont get taken for lots of money :D, any how I appreciate the advice.
Thanks
Drue
seagull
Post by seagull » Wed Jul 22, 2009 2:08 am
Drue , can you get your self down to Wichita County ?
If so I may be able to help in the comming months
seagull
Post by seagull » Wed Jul 22, 2009 2:15 am
http://maps.google.com.au/maps?client=f ... a=N&tab=wl
I may well have freight going to kentucky as well
U.SBoy8706
Post by U.SBoy8706 » Wed Jul 22, 2009 2:20 am
seagull wrote:http://maps.google.com.au/maps?client=f ... a=N&tab=wl
Im not sure where Wichita county is but if you can get a freight to kentucky or any surrounding areas i will drive to get one of these trans. That is the state of Kentucky in the u.s. Hopefully we can work something out let me know thanks bro.
Post by AlpineRaven » Wed Jul 22, 2009 9:18 am
U.SBoy8706 wrote:Would the box bolt up to my EJ 5sp trans out of my 94 imp L? Also would you be willing to export to the U.S?
If its EJ engine before 99 with 4 bolts then it will be straightforward swap. If you have single range box then it easy to do. gen 1 lib has 3.9 diff and gen 2lib has 3.7 diff. Yours more likely to have 3.9.
U.SBoy8706
Post by U.SBoy8706 » Wed Jul 22, 2009 10:32 am
AlpineRaven wrote:If its EJ engine before 99 with 4 bolts then it will be straightforward swap.
AlpineRaven wrote:If you have single range box then it easy to do. gen 1 lib has 3.9 diff and gen 2lib has 3.7 diff. Yours more likely to have 3.9.
When you say single range box do you mean a single range trans? The box im trying to purchase is going to be a D\R EJ box and i would be putting it in my 94 Impreza L model. It should be pretty straight forward like you said im just waiting on a response from the seller.
Thanks Again
Drue
Post by AlpineRaven » Wed Jul 22, 2009 5:14 pm
U.SBoy8706 wrote:When you say single range box do you mean a single range trans or implying that if i bight a single range box it would be less difficult. The box im trying to purchase is going to be a D\R EJ box and i would be puting it in my 94 Impreza L model. It should be pretty straight forward like you said im just waiting on a response from the seller.
Thanks Again
Drue
Yup, same thing, what you guys over there have single range awd. Yeah it shld be straight forward job.
But you'll need dual range linkages and levers etc for/from impreza.
seagull
Post by seagull » Thu Jul 23, 2009 1:37 am
U.SBoy8706 wrote:Im not sure where Wichita county is but if you can get a freight to kentucky or any surrounding areas i will drive to get one of these trans. That is the state of Kentucky in the u.s. Hopefully we can work something out let me know thanks bro.
I know were you are, this is were Wichita falls http://en.wikipedia.org/wiki/Wichita_Falls
follow the map link and past in the address on the link I posted to show the route
U.SBoy8706
Post by U.SBoy8706 » Thu Jul 23, 2009 1:54 am
seagull wrote:I know were you are, this is were Wichita falls http://en.wikipedia.org/wiki/Wichita_Falls
Oh ok sorry for the confusion, I've never been down to texas and that is one heck of a drive but if we cant work anything else out I will make the drive to get one of these transmissions. Any chance of haveing the trans freighted from texas to kentucky or a closer state? You mentioned you might have a shipment comeing to kentucky? How much would you want for the trans?
Post by guyph_01 » Thu Jul 23, 2009 2:00 am
well i still have the D/R box with all the linkages attached for sale with the matching diff. Its from a 91 first gen so should be 3.9 as AlpineRaven said. Will check to see if i can spot a label. I never posted a gearbox before so im not sure where to go or what to do.
U.SBoy8706
Post by U.SBoy8706 » Thu Jul 23, 2009 2:02 am
guyph_01 wrote:well i still have the D/R box with all the linkages attached for sale with the matching diff. Its from a 91 first gen so should be 3.9 as AlpineRaven said. Will check to see if i can spot a label. I never posted a gearbox before so im not sure where to go or what to do.
Sounds good im still interested, and if i dont end up buying it my roommate will! Is there any way you can post some pics or emails me a few? Are you firm on $450 and is that AU or US currency?
U.SBoy8706
Post by U.SBoy8706 » Thu Jul 23, 2009 2:21 am
AlpineRaven wrote:If its EJ engine before 99 with 4 bolts then it will be straightforward swap. If you have single range box then it easy to do. gen 1 lib has 3.9 diff and gen 2lib has 3.7 diff. Yours more likely to have 3.9.
My 94 impreza L series is a 4.11 final drive, the box should still bolt up with this application right? Or is there something I dont know? Appreciate all the help and advice Alpine.
Thanks
Drue
Outback bloke
Post by Outback bloke » Thu Jul 23, 2009 7:13 am
Yes the box will bolt up. You do need to make sure you have matching front and rear diff ratios. If yours is a 4.111 then you will need to swap your rear diff or when you get the boc put your front diff in to the new one. There is a bit of machining work that is needed to be done to the crown wheel to make it work with the dual range gearset.
If you don't manage to find one from a private seller you can get in touch with Sunspares. I don't like directing people to them any more as they aren't as helpful as they used to be. Having said that they generally have every thing you need up there.
http://www.sunspares.com.au
U.SBoy8706
Post by U.SBoy8706 » Thu Jul 23, 2009 11:30 am
Outback bloke wrote:Yes the box will bolt up. You do need to make sure you have matching front and rear diff ratios. If yours is a 4.111 then you will need to swap your rear diff or when you get the boc put your front diff in to the new one. There is a bit of machining work that is needed to be done to the crown wheel to make it work with the dual range gearset.
Thanks for the advice and link bloke, after reading through alot of posts im a little torn on which way to go with my project. I was un aware that all EJ D\R have a 1:19:1 low which wouldn't help my situation much as im running an EJ 1.8L with 28" tall tires. Im thinking about just swapping one of the EAs part time awd D\R with the 1:59:1 low into my car instead. I've heard the part time ea82 D\R have a 1:59:1 low range as the full time D\Rs have a 1:19:1, can anyone confirm this? These transmissions are easier to come by in these parts and would probably end up costing relatively the same as haveing a EJ box shiped here from the AU. The only problem is i would like to retain my 4.11 final drive and i dont think its possible to put the front diff from my EJ transmission into my EAs. Anyone here have any expereience with this swap?
