Recondition or replace brumby gearbox?
Hi My newly acquired 1984 Brumby has a lot of oil leaks around the gearbox. When I checked the oil level it was virtually empty! My question is would it be cheaper to remove the GB and fix the leaks or put in another GB? What could I fit? I notice there are always a lot of L series wagons being wrecked, could I fit one of those GB's to my Brumby? Would it be a direct bolt in with mods? If not what would you suggest? thanks Spin.
A few people have fitted an L series 5 speed into the brumby. If you look in the gearbox section, you should find what info you need.
rtcb65
Redneck Rick.
Redneck Rick.
- brumbyrunner
- Suby Wan Kenobi
Unless the oil is coming out of the gearbox input shaft you can replace the seals with the gearbox in position, you do have to remove the CV's and tailshaft though. As already been said now would be a good opportunity to upgrade to a 5 speed gearbox. You will also need to replace the clutch plate at the same time as they are different from the 4 speed input shaft spline. You will also need to adapt the 5 speed gear selector and low range lever as well as adapt the longer L series tailshaft or get a custom sinlge piece shaft made.
The long road ahead
The long road ahead
can you specifically tell us where is it leaking from?
if its leaking from where the drive shafts/drive train areas, these are seals and costs about $8 (each) to replace but if its leaking from the joints then the gearbox has to be removed to re-seal hence might be good timing to rebuild or replace to l series with 5 speed like one of these guys said above. I can tell you now that rebuilding the gearbox would cost you between $1500 - $2000 whereabouts you can get 2nd hand one for about, $80 minimum upwards depending which wrecker you're at.
Thank you for the replies. You have all given me some great advice and options. Firstly I will check on the weekend exactly where the oil is coming from. Based on that, I will then consider my next option. The gearbox was somewhat noisy until I put more oil in it! Seems ok now although the gear shift has a lot of movement in it but never having owned one before, not sure if that is what they are all like? Will let you know what I find next weekend. thanks for your help Spin.,
- brumbyrunner
It would be good idea to power wash the gearbox to give you better clearer indication of where the leakage is.Spin wrote:Thank you for the replies. You have all given me some great advice and options. Firstly I will check on the weekend exactly where the oil is coming from. Based on that, I will then consider my next option. The gearbox was somewhat noisy until I put more oil in it! Seems ok now although the gear shift has a lot of movement in it but never having owned one before, not sure if that is what they are all like? Will let you know what I find next weekend. thanks for your help Spin.,
- subybrumby
Member FROG is your best bet..will probably contact you or his details are on here in the members list. I've bought before thru him and he has been most helpful.
To correct some information: To do the L series 5 speed gearbox and have the 23 spline diff output stubs and the good 1.59:1 low range you need any 5 speed dual range gearbox from the NATURALLY ASPIRATED L series. The MPFI and MPFI turbo have 25 spline counts. The MPFI turbo has the dodgy low range (1.19:1) I believe.brumbyrunner wrote:Yes, the 5 speed gearbox is a good upgrade.
Make sure you get one from a Touring Wagon to get the 1.59:1 low range and the 23 spline output shafts.
I can vouch for FROG as well. Many parts have keep oz post in business and FROG with a jobsubybrumby wrote:Member FROG is your best bet..will probably contact you or his details are on here in the members list. I've bought before thru him and he has been most helpful.
