vortex ea82 vortex 1.8L knock sensor?Where is t
vortex_06
Post by vortex_06 » Sun May 17, 2009 6:02 pm
Hi i was wondering if anyone knew where the knock sensor on vortex ea82 engine is.Also the firing order and timing sequence for this engine.Thanx
Post by Gannon » Sun May 17, 2009 7:00 pm
The knock sensor is located near the left middle of the engine block at the back, pretty much to the right of the turbo,.. if you are looking down on the engine.
Mine is green and has a single wire going to it.
Firing order is 1324 (cylinder 1 is under the thermostat, cylinder 2 is under the alternator, cylinder 3 is nearest the turbo and cylinder 4 is closest to the distributor)
vortex_06
Post by vortex_06 » Sun May 17, 2009 7:19 pm
Thanks for that :)
