knock from somewhere....
shuffbag
Post by shuffbag » Mon Mar 23, 2009 8:00 pm
befor the sun comes up and i have the car on stands, anyone like to guess as to my mystery knock is??
you can feel it through the floor in the pasanger footwell mostly (so i've been told, i don't sit there) the knock only appears when taking off normally and turning. i reverse out of a driveway, slight turn, touch the brakes and then KNOCK!
engine mounts are still intact, so are the gearbox mounts (i think. can someone tell me, are there only two rubber blocks joined to either side of the gearbox mount?)
oh and it seemed to miss 3rd on first go driving home, reclutch and in it goes! arrgggghhhhhhh.
and it did it to me just then driving home down gearing, i thought i selected 3rd but nope i was in N. could the gearbox be moving on its mount to much (side to side or something)?
90brumby
Post by 90brumby » Mon Mar 23, 2009 8:08 pm
could b lower control arm bushes but hard to say with out actually hearin it
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by AndrewT » Mon Mar 23, 2009 8:14 pm
Could be loose lift block bolt one one of the 3 points where the radius rod plate bolts to the floor pan. Problems around that area are common to feel with the passenger's feet. Check the radius rod bushes too.
shuffbag
Post by shuffbag » Mon Mar 23, 2009 8:20 pm
i spose if the bushes are knackered, when the cars on stands with no weight i should feel freeplay yeah? when i wobble it.
blocks/bolts will be easy i can turn a spanner
Post by El_Freddo » Mon Mar 23, 2009 11:07 pm
Might wanna check your brake caliper?!
I've got a random knock that only happens when turning or on a 'gentle' bump when turning - not as you turn the steering wheel but as you hold it in a turn. Haven't heard it in a while but have replaced my front bearings and shafts...
To feel it through the floor points to the radius rod or something with the bracket that holds the radius rod...
If the gearbox bushes are worn appearntly you feel it when you change from Park to Drive or Reverse etc.
shuffbag
Post by shuffbag » Tue Mar 24, 2009 4:27 am
mine is manual.
Subaman
Post by Subaman » Tue Mar 24, 2009 7:31 am
Yeah I agree, really sounds like a loose liftkit block .
shuffbag
Post by shuffbag » Tue Mar 24, 2009 3:06 pm
ROFL! you can forget about popping out of 3rd, forget i even typed it :)
and it appears lift blocks.
i put the front on stands and try'd twisting the blocks on the pasanger side, one moved so i tighten them all up... all good
move to the drivers side, the bolt that goes through the bracket and gearbox crossmember loose! go to tighten it up and it chews the thread out of the nut. resulting in drilling/tapping/$30 bolt!! (i have had to do this on my wagon before but other side)
then i go to tighten the other two one is sweet, but then BANG the other chews out the thread on the nut. aarrrgggghhhhhhhhh now i am waiting on my hired help to get back with another $30 bolt to get rid of my knock once and for all.
shuffbag
Post by shuffbag » Tue Mar 24, 2009 5:16 pm
knock is gone, i only have smaller knocks now but i'm putting them down to the rod bushes as there was a fair amount of movement in them (whilst reversing and braking).
and one other knock is the cat on the radius rod bracket but thats no biggy.
