EJ22 into L Series
EJ22 into L Series
hey all, have some questions that id like some answers on.
as im about to put my new motor into my car, i was thinking what simple mods are there that i can do to the engine while its out to get just that little bit more out of her. things like porting the throttle body or modifying the intake system ect. just things that people have done to get more out of it.
also, what set up for the fuel system is best? were unsure how to attack this and all ideas and knowledge on the fuel system would be much appreciated.
thanks for reading and your helpful input
1989 L Series Wagon
3" lift, 27/8.5/R14 Muddies
EJ22
EJ22
I have done:
Complete rebuild
Deck heads & block to raise compression.
Port & polish head.
Performance stainless steel valves.
High rate valve springs.
Custom exhaust headers.
AFM / timing control (Custom built by me)
Adjustable FPR.
I am still yet to run this motor.....
But I am hoping for a reasonable power increase.
Complete rebuild
Port & polish head.
Adjustable FPR.
http://www.subiparts.com.au
0438 887 746
0438 887 746
With the throttle body there's not much you can do. Its the same size as the turbo (EJ20G/T)
The best thing you can do to the EJ22 is put a can of Subaru upper engine cleaner through it. And do regular oil changes. Just to keep the motor clean.
0438 887 746
0438 887 746
Can put a supercharger on....but I guess that's far from simple in the end, even though it is technically just a "bolt-on" mod. Check out Subarino's setup.
The best bit about this is that you can gather the bits here and there when you can afford them, then put it all in when you've got it all sorted...AndrewT wrote:Can put a supercharger on....but I guess that's far from simple in the end, even though it is technically just a "bolt-on" mod. Check out Subarino's setup.
I use this method all the time, its actually how I got my car on the road then the motor rebuilt (then ended up toasting that engine due to a dodgy radiator 9 months later) while I was at uni. My subi unfortunately got neglected last year, this year the tide is turning
While you're at uni you can stick with the EJ, without having an EJ in my L, I'd say this should keep you smiling at least while you're at uni, once you're out working fulltime, then start the performance mods if that's what you're after...
i gotta wait til i finish my degree b4 lift kits, lockers, winches etc are nice and claimable...
wouldnt it be easier to just put a turbo on instead? i mean, all u gotta do is plumb her up and shes great.
then again, whinning is better than pssssssssssssshhhhhhhhhhhhht...
1989 L Series Wagon
EJ22
EJ22
