ej20t engine into L series
Mr Top Hat
Post by Mr Top Hat » Sun Mar 15, 2009 4:19 pm
hi my names Rob
i currently have a 90 L series with a 1.8l ea82 engine
i am planning to put a ej20t engine in it
is it reasonably easy to do ?
i want to keep the original gear box for the hi and lo gears
is there any chassi mods involved ?
Post by El_Freddo » Mon Mar 16, 2009 5:26 pm
G'day Rob, welcome to the forum.
Probabily best to read this and remember that you're reading for info on the L series only.
After reading that, any other questions you have others will beable to answer ;)
Post by AndrewT » Mon Mar 16, 2009 7:25 pm
Yeah it will work but stock up on gearboxes and take out life insurance, they don't last with that much power and it gets abit hairy sometimes when you have the ability to break traction on the wheels that are steering you at practically any speed.
It's not that hard to do, all the info is around here, spend a good few hours reading up on the forum.
Post by Alex » Mon Mar 16, 2009 7:30 pm
its an awesome conversion.
i have EVERYTHING you need to do it here if you're keen. When i say everything, i mean everything. Custom radiator, chopped down wiring loom, 2.5 inch exhaust, low km import dual range gearbox, adapter plate, cut xmember, evrything!
no chassis mods involved. Its a pretty strait forward conversion.
cheers
Mr Top Hat
Post by Mr Top Hat » Mon Mar 16, 2009 9:18 pm
i had a read through
pretty useful
question
is the ej20t larger than the ej20 in size i mean
Mr Top Hat
Post by Mr Top Hat » Sat Mar 21, 2009 6:53 pm
and can you put a bov on a stock EJ20T
Post by El_Freddo » Sun Mar 22, 2009 1:25 am
t35345 wrote:is the ej20t larger than the ej20 in size i mean
Same size in capacity but the turbo is lower static compression to the NA EJ20.
t35345 wrote:and can you put a bov on a stock EJ20T
Most likely. I don't know much about these but I'm sure they have some sort of Factory BOV that's plumbed back into the air intake so not to trip out the ECU.
Hope this helps a bit.
Post by Subafury » Sun Mar 22, 2009 11:27 am
this conversion will increse the fun factor on your L series by x100. just take it easy on the gearbox and you'l be fine.
go check out Keffa's car for a first hand look at all the bits u need (for sale too), he can explain it.
Post by AndrewT » Sun Mar 22, 2009 12:01 pm
LOL at the BOV question.
You can put shiny pod filters on them too. :)
Post by Alex » Sun Mar 22, 2009 5:26 pm
they have a stock bov which makes a nice psht noise which is well than loud enuf. Otherwise youll need a semi or full plumb back bov.
Josho
Post by Josho » Sun Mar 22, 2009 10:23 pm
just having a read through here i'm looking at buying a wrx halfcut for my l series as yesterday after having a wee bit too much fun i discovered a hint of oil in the radiator car not over heating but not looking good:( think the ej might be dying,
Post by El_Freddo » Sun Mar 22, 2009 10:26 pm
Josho wrote:just having a read through here i'm looking at buying a wrx halfcut for my l series as yesterday after having a wee bit too much fun i discovered a hint of oil in the radiator car not over heating but not looking good:( think the ej might be dying,
EJ or EA?? If you've got the standard 1.8 litre motor in there its an EA and would be worth upgrading to the EJ in most people's opinion...
Josho
Post by Josho » Sun Mar 22, 2009 10:29 pm
El_Freddo wrote:EJ or EA?? If you've got the standard 1.8 litre motor in there its an EA and would be worth upgrading to the EJ in most people's opinion...
already an ej 94 lib motor
Mr Top Hat
Post by Mr Top Hat » Sat Apr 11, 2009 2:30 pm
hey again
i was talking to the guy's at work and they reckon that i need at leased a 3" exaust system coz the ej20t is larger or somthing
i hope not coz i just got a 2" catback system last year
someguy
Post by someguy » Sun Apr 19, 2009 6:35 pm
t35345 wrote:hey again
AFAIK you will be fine with the 2"
Post by AndrewT » Sun Apr 19, 2009 8:52 pm
2" would restrict it slightly as the stock exhaust on an RS is 2.25". At least it is as it comes off the dump pipe. But you will get away with it.
3" is absolute overkill - totally not needed unless you are modifying for big horsepower.
Mr Top Hat
Post by Mr Top Hat » Mon Apr 27, 2009 11:59 pm
ok now im totally confused
some people said that the EJ20T/G
just fits right in to a l series
but other people say that you need to do some welding and cutting to the chassis rails
sorry to keep bringing this up but i just want to know that im making the right choice engine wise
thanks
Rob
Outback bloke
Post by Outback bloke » Tue Apr 28, 2009 7:49 am
That is right on the money. A better/newer dump pipe is a good upgrade but you only need to go back as far as the flange on a standard motor.
The EJ20 turbo will fit an L series with out doing any cutting to chassis rails and that is a definite. No confusion about it. You do need the crossmember modded to suit the up pipe though.
Post by AndrewT » Tue Apr 28, 2009 11:01 am
Yep. I think some of the confusion might be exactly what needs cutting/welding and exactly what car is being talked about.
EJ20G into L series car;
Chassis rails = No modification required
Engine crossmember = Cut/weld slightly to clear turbo exhaust manifold OR swap for an engine crossmember from a EA82turbo L series (such as Vortex or RX Turbo) but these are abit rare these days.
EJ20G into MY series car;
Chassis rails = Cut/weld to widen slightly to clear the plastic engine timing covers
Engine crossmembers = Cut/weld slightly to clear turbo exhaust manifold OR swap for an engine crossmember from a EA81turbo MY series but these would be near impossible to find.
All this info is in the sticky thread about putting EJ engines into L or MY cars at the top of the Conversions section.
wagonist
Post by wagonist » Tue Apr 28, 2009 4:43 pm
I'm about to offload my EJ20T (93 WRX) with cutback loom if you're interested;)
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
