tap tap tap liberty
- bendigojet
tap tap tap liberty
hello to all this is my first post but not my first subi just bought a 1990 liberty gx auto 2.2 4wd wagon on the wkend ebay bargain $1200 .picked it up its great,but it has noisey tappet noise from drivers side rear cylinder ? yes i know its a common problem .any how i ran some lifter clean in her for 200km noise no better or worse .spoke to local mech and he said oil pump seal sucking air ? to me a "lash adjuster" needs replacing and i assume i can do this myself , rocker cover off ect no need to remove head new adjuster on and on bobs me uncle . if any one can give me some advice or help on this matter it would be greatly appreciated ....chris ,,,or will penrite 50 oil work on really noisey lifters ?
- Thumpage44
The oil pump uses a Silastic gasket & after time it brakes away. Causing oil to pass by the pump. This gives a drop in pressure & the lifters are the first to suffer.
Replace the oil pump gasket with a paper one (aftermarket only) & this will help. If it has been making the noise for a while chances are you have a collapsed lifter. After market lifters are available at about $15 to $20 each.
http://www.subiparts.com.au
0438 887 746
0438 887 746
They are self adjusting and you cannot adjust them yourself.
Give it a oil change and put in castrol magnetic in and go for a long drive with high octane fuel, it will help I am sure, give it a good run on the highway maybe 200kms or more.
- bendigojet
well hey awl ! sat arvo ... had a look at the wrkshop manual . glared at car for about 10 mins .thinking.. it carnt be that hard so i pulled the rocker cover off found that there was a gap in the frnt cylinder inlet valve .collapsed tappet. that would have been making the tap tap tap . so i removed the valve assembly as manual said removed tappet cleaned and bleed in oil , it held preassure so i put it all back together turned the key WOW she purred like a kitten ... nay.... a young panther no more ticks have driven it a bit and all seems ok many thanks to all who gave advice ect.... chris
- Mr Top Hat
- chubby37
there is a small ball bearing in the end of them to stop oil drianing back out...some times the bearing can get stuck and when it does it cant refresh the oil....instant noise...just need to break the seal on the ball bearing and pump it back up by hand in a container of oil and put it back in....i had to do this myself
