Fuel Gauge
Fuel Gauge
Have an intermittent fault fuel gauge gen 1 Liberty.
Gauge will fall to empty then slowly return to correct fuel level.
Fuel sender unit tests ok.
Common fault?
Do I have to pull out the cluster?
Common fault?
i don't think its the cluster. Its the sender unit i think.
- Suby Wan Kenobi
I have the same problem with the sender on my L Series.
Anyone know where abouts its located on the wagon models.
I know for most sedans its under the rear seat but obviously the wagons fuel tank is down the end of the car.
if you want expensive option - buy new sender units will set you back approx $475 for AWD models. You can clean them but won't last long...
Most people here just rely on resetting ODO after filling up and drive until the light comes on and work out average kms before you need to refill.. for example - my Liberty's light comes on approx 550 - 575kms which means I have approx 80- 100kms left of fuel..
- [email protected]
hi,
i was wondering if anyone knew why the fuel gauge would stop working in a L series wagon after pulling the instument cluster out, then reinstalling it. I am sure i have it back in the exact way it came out, and everything else seems to be working fine (ie speedo, temp etc). as soon as i had it all hooked up again, i turned on the ignition and the fuel gauge needle slowly dropped from full to way below empty, and wont move back. have cleaned and checked all contacts. could this be a sender problem?
any ideas???
cheers
Henry
1988 L Series Wagon (the Scooby-Doo)
any ideas???
cheers
Henry
On the series 1 lib you have two fuel sender units too loook at one for the left tank and one for the right also I used an eraser to clean off my senders then hit them with thinners but my fuel light doesn't work so I knew it was empty when it would die on corners!
87 targa brumby (Neglected),
+ others.
+ others.
