L rear drumns on MY - worth it?
Post by El_Freddo » Sun Mar 01, 2009 8:22 pm
G'day all,
This evening while working on Sunnie the Brumby I found a slave cylinder leaking on the rear left. I have a set of L self adjusting drums with decent slave cylinders on them, I was wondering if its worth installing the self adjusting gear onto the brumby (both sides of course) or going out and getting a new slave cylinder to replace the dead one and forget about the adjusting setup...
Matatak
Post by Matatak » Sun Mar 01, 2009 8:41 pm
itll be a simple as swap so why not?
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
90brumby
Post by 90brumby » Sun Mar 01, 2009 9:27 pm
yea if it swaps straight over y not otherwise just adjust them every now n then i never found self adjusteers to b the best thing eva but yea if they fit y not
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Phizinza
Post by Phizinza » Mon Mar 02, 2009 8:57 am
Auto adjuster ones (if working correctly) same you having to get under your car every couple of thousand K's to adjust otherwise your brake pedal feels crap all the time... I've done it to other cars and am doing it to my own now I have a set of L drums.
Post by El_Freddo » Tue Mar 03, 2009 4:05 pm
Well they're on now and do the job well, even though I'll need to put new shoes in there no later than the next oil change.
Very happy and was an easy swap - note: you will need the L series backing plate as it has different indents to fit the self adjusting mechanism...
