WEIGHT of L series A/C kit is...
Post by steptoe » Wed Feb 25, 2009 8:04 pm
thirteen kg in the compressor and its cast iron bracket, for the weight conscious amongst us
Post by El_Freddo » Wed Feb 25, 2009 8:45 pm
Beyond me if you hadn't have posted that... What about the condensor and exchange box under the dash???
Busdriver
Post by Busdriver » Wed Feb 25, 2009 9:01 pm
Lets see now, my L series weighs what 1200 kgs ?, and I weigh about 130 kgs, (Yes I am fat, but its all paid for) So if I took off the A/C I would gain approx 15 Kgs all up and sweat heaps more so the potential is there for me to weigh heaps less? That would have to help my power to weight ratio a lot more than just loosing the A/C and be good for me.
Suby Newbie
Post by AndrewT » Wed Feb 25, 2009 11:16 pm
The under dash bits weigh bugger all - ally and plastic.
Post by steptoe » Fri Feb 27, 2009 8:40 am
the aluminium underdash freezer bit called an evaporator, comes in at 2.1 kg, the plastic casing would be close to a kilo, the receiver drier wouldn't be a kilo but nearly, EDIT ...comes in at 932g ! and 700g of refrigerant ..... so you could probably safe bet be 18kg worth if not working or wanted and removed. Remove wiring and the amp unit behind glovebox....there is more weight loss. I have the Lotus Elise principle applied too - no radio CD player so the speakers don't need to be there either.
Post by steptoe » Fri Feb 27, 2009 8:42 am
1200 for an L ? My turbo sedan is 1070 ! 1070 + 130 = 1200 . Aren't you supposed to jump out at the weighbridge :)
Busdriver
Post by Busdriver » Fri Feb 27, 2009 12:23 pm
I am only guessing here guys, I have not got a clue. So what would an L series wagon weigh?
Might change my thoughts on if wether or not I keep the A/C yet.
And if I get out of the car at the weighbridge, how do I drive it off the weighbridge?
Suby Newbie
GOD
Post by GOD » Fri Feb 27, 2009 2:33 pm
Busdriver wrote:I am only guessing here guys, I have not got a clue. So what would an L series wagon weigh?
1030kg, according to my rego papers.
Dane.
Busdriver
Post by Busdriver » Fri Feb 27, 2009 3:36 pm
Is that all? I misunderstood the earlier post by Steptoe, I thought he must have meant he had a sedan.
I would have thought the wagon was heavier than that, being 4wd and all!
Suby Newbie
Phizinza
Post by Phizinza » Fri Feb 27, 2009 5:01 pm
Manual transmission Subaru weights
Brumby's curb weight is 1018kg
EA81 Wagon curb = 1091kg
EA81 2wd Sedan curb = 993kg
EA82 2wd Sedan curb = 1034kg
EA82 4wd Sedan curb = 1009kg
EA82t 4WD Sedan curb = 1168kg
EA82 4WD Wagon curb = 1179kg
4wd vs 2wd is about 63kg difference IIRC
Post by steptoe » Sat Feb 28, 2009 9:00 am
dunno where phiz got his data....
I was quoting my L Series sedan weight off NSW RTA data sheet for auto 4WD turbo
The Subaru factory manual lists for a the 1986 L series RX turbo sedan 5MT D/R including weight of LSD and hard suspension and AC at 1080 kg
4WD turbo sedan with auto - mine 1095
my Brumby is registered as 975 kg
Phizinza
Post by Phizinza » Sat Feb 28, 2009 11:46 am
I was just quoting data off a scan of a original Subaru FSM that the dealers get....
I wouldn't trust anything the department of transport puts on there... My 83 sedan is registered at what I said it was, 993kg, because the form asked for it and that's what I know it to be. Of cause now its different because I'd stuck 4wd under it.
Post by Gannon » Sat Feb 28, 2009 1:26 pm
dont forget that some weights quoted by the manufacturer are dry weights, without oil, fuel, water ect
