RX L Series Tailshaft vibration issues .
discopotato03
Post by discopotato03 » Mon Jan 26, 2009 10:52 am
Hi all , had this problem ever since I had it (rear half) and the diff out some time back .
I thought I fixed it by lining the paint mark up - think I had it in the wrong way round .
I have an L wagon tailshaft to play with and will soon be to the driveline specialists to get that one "sorted" .
I'd like to look into having replacable uni joints fitted and wonder if anyone has done this with a two piece L tailshaft .
Some Nissans use the same gearbox end slip joint and I happen to have an Aust Bluebird shaft with one of these . I'll have to get hold of a rear uni joint and hooks to suit my R160 diffs companion flange and sort a middle one and and fix any probs with the center bearing and rubber cushion thing .
This would have been lots easier if these tailshafts didn't have staked unis in them .
Any suggestions most welcome , cheers A .
BTW tube sizes need to stay the same because the new exhaust is just clear underneath the tailshaft .
Post by AndrewT » Mon Jan 26, 2009 12:21 pm
so your asking what to do about the vibration issues? sounds like you already have the solution - take it to a driveline specialist (any driveshaft place) and have it 'sorted".
Any half decent place will be able to replace the "non replaceable" uni joints with replaceable ones - this is not a big deal at all, and not rare. Cost me roughly $100 per uni joint when I had it done to a 2-piece L series tailshaft quite a while ago.
discopotato03
Post by discopotato03 » Tue Jan 27, 2009 8:17 am
I just thought someone may pass on which alternative joints are suitable to have fitted - as in the hooks .
Cheers A .
Post by AndrewT » Tue Jan 27, 2009 8:23 am
Ah, that is something I'm going to explore soon as one of my shafts is in need of more joints replaced, I definitely want to see if something more beefy can be custom fitted.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Jan 27, 2009 2:32 pm
Someone here had a single piece shaft made up here a few years ago and im pretty sure he got it made with Falcon Uni's as they where pretty close to the original hole size. I know its a single piece not a 2 peice but the reason Falcon one where used was of the close size to original ones. Judging by the size it would have been early falcon.
The long road ahead
discopotato03
Post by discopotato03 » Tue Jan 27, 2009 4:23 pm
The 5MT L tailshaft is now at Sydney Driveline Services and should have it back towards the end of the week .
I'll basically have a new rear section with Aust spec Datsun yokes and Holden type spider centers . These (XU1 spec ones) don't have the grease passage drilling in the cross piece so are stronger than the greasable ones .
They want to use the original front section and center bearing except with another Aust Datsun yoke and a Nissan slip joint yoke I supplied .
Not going to be a cheap exercise but at least I can service the thing when it never wears out ... And no don't ask .
To crown the day off Ellies spat a power steering pump and is leaking all over the front of its engine . Please tell me L's with dying PS pumps dont give weird driveline type vibrations ...
discopotato03
Post by discopotato03 » Fri Jan 30, 2009 6:34 pm
I picked the new shaft up this afternoon and it looks real good . The only thing that concerns me now is if the length of the front half is right because the front yoke/slip joint is longer being a Nissan one . Fingers crossed they took that into account and moved the front uni south to allow for the extra long slip joint section .
If I get time I'll measure them up over the weekend , anyone have an L 5MT tailshaft they can measure the total length ?
Cheers A .
