how many Ks have you done a single tank
the gumbi brumby
Post by the gumbi brumby » Fri Dec 19, 2008 9:53 pm
as abouve
reason for asking is today was driving around for work after a fair bit of hiway driving.
i reset the trip last time i filled up any way 548.4k i filled up 48L gave it 5 or 6 clicks yep its full
stock 1990 brumby ea81
normal unleaded
can you top this effort
E10 BLEND KILLS CARBY CARS AND RUSTS STEEL TANKS
Post by AndrewT » Fri Dec 19, 2008 10:20 pm
This is a bad comparison obviously as it's a totally different car but food for thought.
I can squeeze ~600 out of my RX if I try (EJ20 turbo) which is only an approximate figure. My odo is out due to several reasons but overall it's only slightly out.
- now running 4.1 final drive ratio (originally 3.7)
- now running RS turbo gearbox with different gear ratios
- now running larger 14" tyres
Come to think of it she's just about empty right now I'll take a photo...
I rekon I could hit 600 with it....I'll try in the morning and post another photo :)
This is on the standard 55litre L series tank, using any old RON95 fuel and not particularly trying to take it easy, still boost up fairly often while I'm driving.
I always reset the trip meter every time I fill up to keep an eye on millage.
Post by D3V1L » Sat Dec 20, 2008 12:20 am
ahahah,,,let me see here :)
80 litres of petrol, and 95 litres of gas gets me 800 kms......hmmmmm.....not very good :)
buggy, 20 litres of fuel got me approx 8 horus of rev limiter goodness at wedge :)
Post by El_Freddo » Sat Dec 20, 2008 11:32 am
L series MPFI standard box/diff's and tyre diametre etc etc.
739km to 60 litres - did the drive from adelaide to central vic (woodend) on one tank :D
Car was lightly loaded and flogged everytime we passed a slow vehicle...
also, I think this is a bit of a chalk and cheese discussion - that said, I'm okay with it.
Post by sven '2' » Sat Dec 20, 2008 11:51 pm
bloody hell!
Never got close to those figures...ever!!
Worst was 125km on a full tank in the EA82T wagon in stinky hot conditions, high revs, low range down Beachport way in shell grit one year.
But we had some fun...
Sven
Phizinza
Post by Phizinza » Sun Dec 21, 2008 9:18 am
AndrewT wrote: - now running RS turbo gearbox with different gear ratios
Speedo is run off the output side of the gearbox, gear ratios don't make a difference. But, the speedo's gear might be different (I doubt this because my 3.7 and 3.9 boxes both had the same speedo gear ratio).
Your diff ratio will change the speedo by 9.25%, so that is it will read faster then you are going. Depending on your tyre size, 215/75R14 tyres are about 18% over stock so you'd be looking at about 9% slow reading. In every 100km you'll read 91km on the odo. Of cause, every brands sizes differ, sometimes as much as half an inch OD for the extact same rated size. So without a tape measure you can't calculate how much out your speedo is.
Personally I don't like the "how many to a tank" measurement as it doesn't translate to other vehicles, or even different models. I always use l/100km. Easy to figure out using how much to a tank as well.
Doing the figures, my dads L series touring wagon would get 645km to a tank, and thats the 60l tank. But of cause, the tank isn't exactly 60l, I once put 62.something in it. But its running like crap with exhaust leaks and shit carby, so no wonder it only gets 9.3l/100km
Post by Alex » Sun Dec 21, 2008 11:54 am
i can get about 650 from atank in my liberty if driven nicely (thats from 45-50l approx)
wagon use to get about 450 to a 40l tank with ea82, ej22 and ej20g its slightly better again.
akex
Post by AndrewT » Sun Dec 21, 2008 12:08 pm
Alex ur wagon should have a 55L tank surely? I've always been able to squeeze around 58L in all my L series, aren't they all the same?
Post by Alex » Sun Dec 21, 2008 2:14 pm
nup, i can never fit over 40l in my tank. But i never run it uber dry. I think ive once squeezed 45l into it. And no, its not dented.
Post by steptoe » Mon Dec 22, 2008 9:23 am
My 92 Brumby returned 609 kms to dry on its newly built engine EA81, never refilled it - went to LPG
Post by AndrewT » Mon Dec 22, 2008 11:05 am
Keffa wrote:nup, i can never fit over 40l in my tank. But i never run it uber dry. I think ive once squeezed 45l into it. And no, its not dented.
actually don't mind me, from memory actually there might be a difference between the Touring Wagon models and others. And I guess my RX sedan has the larger tank too.
Post by AndrewT » Tue Dec 23, 2008 7:53 pm
After I posted that photo of my dash the other day I got it to 587 before pulling into a servo and filling up, fitted 58litres in after a few clicks.
A few days later now and I managed to get 607kms out of it. She's pretty much bone dry now, stuttered slightly going around the bend just near my house :)
Post by steptoe » Tue Dec 23, 2008 9:27 pm
Wow, Andrew, is this an EJ20 turbo'd RX as in L series. Nice economy !
CPOCSM
Post by CPOCSM » Fri Dec 26, 2008 10:27 pm
El_Freddo wrote:L series MPFI standard box/diff's and tyre diametre etc etc.
Ditto above - got near on exactly this when the engine died due to no petrol(had another 10 litres in the boot...teehee)
Needs a tune now as I am only getting to sydney and back on a tank(mind you I have been using the 91 RON stuff)
Hooroo
Rob Forsyth
Post by AndrewT » Fri Dec 26, 2008 10:50 pm
steptoe wrote:Wow, Andrew, is this an EJ20 turbo'd RX as in L series. Nice economy !
yeah, just normal economy for a Liberty RS turbo really. Maybe slightly better due to a couple of hundred kilos weight reduction being in an L series.
2coupedup
Post by 2coupedup » Sun Dec 28, 2008 2:11 pm
760kms on shell v-power fuel cruising TILL THE FUEL LIGHT CAME ON, 82 leone coupe fwd 1.8 with 32/36 webber carby (that leaks fuel out the main gasket) and extractors n usual sports exhaust
