L-Series Clutch Pedal
R1173
Post by R1173 » Wed Dec 03, 2008 8:30 pm
Why do I only have about an inch of travel? Clutch pedal & cable have been replaced & the problem still exists.
Hayden.
discopotato03
Post by discopotato03 » Wed Dec 03, 2008 10:59 pm
Is this an RX turbo or a non turbo L series ?
A .
Post by Alex » Wed Dec 03, 2008 11:03 pm
clutch cable not installed correctly is my only idea.(or your clutch pedal is bent DOUBTFUL!)
R1173
Post by R1173 » Thu Dec 04, 2008 4:42 am
Tis a pov pack wagon.
BrennyV
Post by BrennyV » Thu Dec 04, 2008 9:00 am
Keffa wrote:clutch cable not installed correctly is my only idea.
+1 or incorrect model cable installed.
Hunter S. Thompson
Post by AndrewT » Thu Dec 04, 2008 11:25 am
It's very unlikely for him to have the wrong clutch cable, or a bent clutch pedal as he has stated both have been replaced and "the problem still exists" which implies he had the exact same problem before replacing them. Unless he has gotten the wrong model of clutch cable again (how long was the last one in the car?) or somehow gotten another bent clutch pedal.
I would say there is an adjustment somewhere that has been missed, or it's been installed wrong. I can't remember from the last time I was under the dash but check where the cable mounts up near the pedal that it's mounted properly and if there is an adjustment. Otherwise adjust down at the other end of the cable ontop of the gearbox.
Got any more detailed photos of the installation? That will help heaps.
R1173
Post by R1173 » Thu Dec 04, 2008 5:07 pm
I think it may have something to do with the pedal box. ??? Yes, both the replaced clutch cable & pedal were the same dimensions, nor damaged.
I shall get some more pix on the w/end.
Cheers guys,
Hayden.
R1173
Post by R1173 » Sun Dec 07, 2008 8:01 pm
Here are more pix of the pedal box.
mattl200
Post by mattl200 » Sun Dec 07, 2008 8:52 pm
has the clutch also been replaced there are a few differant size thurst bearings took me a while to find the right one when i converted to lib gearbox with lseres low range
or check adjustment and make sure the bracket or clutch fork arnt bent on the gearbox end
Post by Alex » Sun Dec 07, 2008 9:05 pm
can you get some photos of inside the engine bay ontop of the gearbox where the clutch cable comes out?
i suspect this is where the problem is.
Fang
Post by Fang » Sun Dec 07, 2008 9:20 pm
This happened in my L Series recently. We had some of the clutch cable parts behind the clutch fork instead of in front
R1173
Post by R1173 » Mon Dec 08, 2008 7:38 pm
LTurbo
Post by LTurbo » Thu Dec 11, 2008 9:45 pm
This is how it is for me as well mate. Looked at everything, correct cable, bent parts, pedal box assembled right etc... still does it, got me miffed. I am down to thinking its something to do with the clutch/pressure plate, but that does not really make sense. Anyway way will know within the next month as I am going to change my worn clutch soonish.
Your pics look normal to me.
Matatak
Post by Matatak » Thu Dec 11, 2008 10:09 pm
you dont have a return spring off of the fork is what i can see.
so your clutch still works fine as it is?
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
R1173
Post by R1173 » Fri Dec 12, 2008 4:59 am
Most of the time. Can be reluctant to get into gear sometimes, but other than that it works fine.
Post by Alex » Fri Dec 12, 2008 10:16 am
it all looks correct. My final thought is it could be a bent clutch fork? other than that im stumped!
Post by El_Freddo » Sat Dec 13, 2008 12:35 pm
I reckon it'll be the clutch fork pivot bolt in the bell housing - if the retaining nut is not properly tightened, it can slowly wiggle its way down the available thread as the clutch is used over time. If every thing else is in good order this is my bet. The only way to fix this is pull the motor or gearbox. Just make sure you don't adjust it out so far that the pivot will rub against the clutch pressure plate housing - I almost did this with mine.
Good luck with it.
LTurbo
Post by LTurbo » Tue Dec 23, 2008 3:58 pm
El_Freddo wrote:I reckon it'll be the clutch fork pivot bolt in the bell housing - if the retaining nut is not properly tightened, it can slowly wiggle its way down the available thread as the clutch is used over time.
I fiddled with this assembly (clutch fork) and tightened everything back up again, installed a new clutch, and now everything works as it should. Since I changed the clutch as well I cannot say for sure that it was the clutch fork pivot bolt, but it was mostly likely the cause as the old clutch was not toooooo bad.
R1173
Post by R1173 » Wed Dec 24, 2008 11:59 am
I'll try to have a look @ it during the holidays.
