Stirring porridge=changing gears
- subarutility
I have been told that there is a roll pin that wears out in the gear linkage on Subarus: has any one changed this part? is it hard? any hints?. I already have the part, it only cost $2.25 from Subaru. Might have a go this afternoon...
if your talking about a brumby 4 speed....
then the best way it seems to fix it is to replace the roll pin with a bolt and nut
and cut a slot in the linkage so the bolt squashes it together and making it a tighter fit
im pretty sure ive seen pics of it around here somewhere, but ive done it this way and works a treat!
I'll second that - Sunnie the brumby is going strong on this mod. Also replace the bush in the top of the gearbox slot for the gearstick - you'll feel like you have a sports shift after you do the two of these things!bluesteel wrote:if your talking about a brumby 4 speed....
