overheating leone
overheating leone
Can anyone help?
I have a 1986 Subaru Leone 1600cc. It is overheating and I have already replaced radiator and removed the thermostat. The waterpump doesnt make any noises or leak fluid so I dont think that is the problem. Motor is also gutless and strugles to get over 90 km/hr.
G'day subi leone,
This can be a tricky one, especially if you've replaced the radiator, I'm presuming with a brand spaning new one... Some questions:
If you ran the engine without the radiator cap on does it blow bubbles constantly?
Any water in the oil? Is it using any water?
The uderly on the passenger side - is it wet?
How old is the water pump? Is it the original unit as far as you know?
The reason I ask these is because it could be: blown head gasket, hole in the heater core loosing coolant or the water pump - the rotating fins corrode off.
If your radiator is second hand I'd suggest you take it to a radiator specialist and ask them to rod the core - this will remove any gunk that's restricting water flow - pretty common in an old L. If the radiator place tells you that the second hand radiator is cactus bite the bullet and get a new one - check to see if its worth getting a custom one made. I had a 3 core made for my car - $450 last feburary, a standard single core was $333. I have had to remove my mechanical fan and replace it with another thermo which I did last week, it's been fantastic when 4wding.
Anyway, let us know about the answer to the questions. To check the oil one run the engine for a bit first - if its milky its a headgasket...
Also check to see if the radiator core if physically too hot to touch when the motor is really hot (but not cooking the motor of course!).
Nope
Nope and Nope
Nope
Original as far as I know
Oil Not milky
Thankyou very much for your help
Nope
Nope and Nope
Nope
Oil Not milky
Hey subyleone, does the beast have points in the distributor or is it an electronic one? Just wondering because it sounds like your timing might be retarded (sorry to be politically incorrect-Nah im not) as this will cause overheating in drastic examples and will also knock your performance i.e 'wont go over 90 k" and if it had points fitted poorly, this might be possible, so maybe chuck a timing light over it and see what it is running at?
Let us know, because keeping these beasts cool seems to be an ongoing thing.
Suby Newbie
Suby Newbie
DO NOT leave the car running too long without a thermostat otherwise your block will develop hotspots and cause all kinds of grief. Doing so will also mask more than it fixes. With cars I own that dont have thermostats I have had to put blankng sleeves in to stop the hotspot issues(Ford EL's, Nissan Patrol and soon the Mini will be thermo - less as well!!) as they restrict the flow of water through the engine and prevents these hotspots.
Bite the bullet and take it to a rad place - they will let you know exactly what it is - bush mechanics will only mask the issues and are a temporary fix at best.
My money is on the radiator/heater core being blocked and in need of a rod clean followed by the water pump(if this is the case - try and avoid the aluminium alloy ones - they act like a sacrificial anode on a boat and corrodes away).
Good luck though - let us know what it is when you do find out
Hooroo
Hooroo
Rob Forsyth
Sorry to be ignorant, but can someone tell me what an uderly is? Dont wish to hijack this thread, but I have never heard of an uderly unless talking about cows
Suby Newbie
Suby Newbie
Sorry, that way my "quick typing" typo - its meant to be underlay, meaning the sound dampening stuff under your carpet/lino floorBusdriver wrote:Sorry to be ignorant, but can someone tell me what an uderly is? Dont wish to hijack this thread, but I have never heard of an uderly unless talking about cows
Also, ALL L series have electronic distributors - if yours doesn't, someone's been playing funny buggers on your L at some point...
No worries El Freddo, I can usually work out what someone was trying to say when they have a typo, but that one had me beat. Never thought of underlay, only words that i could imagine were things like carpet, vinyl or floor,and I couldnt see how to get uderly from them, guess im just a boob sometimes.
Suby Newbie
Suby Newbie
thermostat
the thermostat must have been taken out before I had the car wich was a good 8 months ago. Going to garage to get one soon. Also it doesn't seem to be overheating quite so bad now but still isnt right. It has been doing nothing for a month and a half would that affect it at all?
- discopotato03
MUST MUST MUST CHECK the ignition timing . EA82's react very badly to retarded ignition timing . When I got my RX Turbo the timing was set to 12 degrees instead of 20 , made a hell of a difference setting it right .
The coolant temps were immediately lower and the part throttle torque became much better . That engine was 250K old when I bought my car and has just today clicked over 290 .
Any mechanic can quickly check and set the timing and idle speed , really easy to do - at least on an injected EA82 anyway .
Make sure you know the correct setting for your model (should be on a sticker on the underside of the bonnet) and insist on setting it to foctory spec to start with .
Cheers A
And did I mention to check the ignition timing ....
Cheers A
Now i am confused. Car has been running sweet and gauge hasnt been moving as much but a cuple of min after a 20 km run i removed the radiator cap because it felt really hot. it was as it just emptied the radiator water rebounding off the bonet everywhere. burnt my hand too. anyway I'll be getting a timing light soon so ill have a look round with that and see what I find
the radiator cap should get hot dude. The car will run at a constant 80-90degress. NEVER EVER EVER remove the cap when the car is hot. As youve found out. Its sooooooooo dangerous!
If it is runnning sweet again, it may just have had a air pocket in the system which has since bled out.
just dont take the cap off when the cars hot mate! unless you want serious damage to yourself and anyone standing around you.
