brumby hid xenon upgrade
MOONEY
Post by MOONEY » Mon Oct 13, 2008 3:39 pm
hi i was just looking at these kits on ebay but i just looked at my lights in my 88 brumby and i have never seen lights like these before lol i was wondering if it is possible to put the kits on these lights
thanks alex
Wilbur
Post by Wilbur » Mon Oct 13, 2008 3:40 pm
If it's the brumby in your avatar you may need to buy some semi sealed beam lights and use H4 xenon kits.
MOONEY
Post by MOONEY » Mon Oct 13, 2008 3:51 pm
nah thats not mine i wish it was mine lol and mine has the single head lights
MOONEY
Post by MOONEY » Mon Oct 13, 2008 4:01 pm
i have changed it to my brumby
Wilbur
Post by Wilbur » Mon Oct 13, 2008 4:08 pm
They are the same as Hilux headlights then. IPF ones work well.
MOONEY
Post by MOONEY » Mon Oct 13, 2008 4:13 pm
it has a funny 3 pin plug on the back if that helps and do i have to change my hole light setup or can i get a kit to suit and what are these types of globes called
Wilbur
Post by Wilbur » Mon Oct 13, 2008 4:20 pm
They are usually sealed beam. If there is nowhere to change the globe, then that will be case and you will need to head out and get some semi sealed beam lamps, and a H4 bi-xenon HID kit if you want both high and low to be HID.
MOONEY
Post by MOONEY » Mon Oct 13, 2008 4:26 pm
i think i might just get some big spot lights might be easier
dwayneb
Post by dwayneb » Mon Oct 13, 2008 4:30 pm
Mooney, go to a 4x4 wreaker, and buy some semi sealed lights from an 80series cruiser - should fit. Finally a good use for a Toyota:-D
Post by El_Freddo » Sun Oct 19, 2008 1:12 pm
MOONEY wrote:i think i might just get some big spot lights might be easier
What about also wiring in some new relays and wiring to the lights? Its pretty simple to do and the improvement in the standard lighting is great from those who have done it.
