idle, making me sound dumb
Post by Subafury » Sat Sep 20, 2008 1:33 pm
hey guys
this is making me feel like abit of a noob but i cant adjust the idle on my ej22.
it was idling high before, and now that i swapped throttle bodies its gone even higher.- 1500rpm.
ive tried the idel screw but that aint doing jack. i also noticed that if you twist the tps that the idle goes up further but obviously wont go down.
any other hints or ideas that could be making it go so high?
Captain Obvious
Post by Captain Obvious » Sat Sep 20, 2008 1:45 pm
IACV is your answer probably creamy color left of the TB under some hoses on the ej22 ithink
bryan
SuBaRiNo
Post by SuBaRiNo » Sat Sep 20, 2008 3:09 pm
You do know that the top visable screw is pretty much a fake adjustment and the true throttle adjustment is actually under the throttle linkage?
Also the Air Bypass Control Valve that Captain Obvious suggested is a ECU controlled Idle adjustment and the actual throttle adjusters should never be used to increase the idle. The throttle adjusters are just there so the throttle doesn't stick shut by closing the butterlfly too tight.
If the IABC is at fault though you should be getting a code.
Could also be an air leake between your throttle body and manifold. I would imagine if it was an air leake before the throttle body then the IABC would be able to compensate. Coule be a minfold to Engine leake too.
Could also be the Trottle Position sensor is not adjusted correctly. This is on the throttle body and is extreamily sensitive to adjust. If you changed this from one Throttle body to the other then there is a very high chance the adjustment is out. Gregories Lib manual covers how to adjust it correctly.
Also after every main part swap on an EJ engine i have found that reseting the ECU is a good idea. Im not sure if there is a fast way of doing it... everyone says something different but i simply unplug the ECU or take my battery off for the night. In the morning it should idle high until the motor is warm and then hunt and auto adjust your idle. Thats if nothing it adjusted wrong or faulty.
I hope this helps some. Unfortunately there is a lot it could be at this stage.
Dave
Post by Alex » Sat Sep 20, 2008 3:52 pm
ive noticed its like a cold idle(higher obviously) but it doesnt drop back down to normal idle after it warms up...could this be something?
also matt said he's never seen it do the higher cold idle thing and then drop back down to normal idle rpm.
just another idea.
Post by Subafury » Sat Sep 20, 2008 4:19 pm
cheers guys, a few ideas to check out there.
i dont know if i have any codes as the check engine light isnt workin
but i will reset the ecu and tweak a couple things and see how i go
shuffbag
Post by shuffbag » Sat Sep 20, 2008 4:23 pm
the top portion of the iacv can be loosened (2 screws on top) then just twist the top to your required idle should require only a small movment.
SuBaRiNo
Post by SuBaRiNo » Sat Sep 20, 2008 4:38 pm
Perhaps a wiring problem and the Start wire is remaining on... hence tweak timing and raising the RPM. Just an idea... would also throw a code though.
Does your ECU have the little hole in the side with an engine light in there... half of them seam to have this.
Dave
Post by Subafury » Sun Sep 21, 2008 4:20 pm
no no hole in the side of ecu.
It is the ecu doing it all tho because:
i was seeing if i could get the CEL working and plugged in both test connectors- resetting the codes. then the next time i started it up was working like a dream- thermos didnt come on automatically, rpm went down to 7-800rpm and was hunting for the ide a bit too. but then the next time i started it up it, it reverted back to the way it was.
