Well the rear diff is all done and I'm about to fit the engine. I have a Weber carb and have modified a standard Brumby air-box to fit it so I can keep the K&N filter. This version of the brumby (its a late '91) has a plastic continuation pipe that goes across the engine bay from the end of the usual air-box and tucks up inside the right wing. I want to fit a snorkel to this. I could fabricate something out of pipe etc but want to get a good finish especially where the snorkel goes through the wing so am thinking adapting a Safari snorkel or similar from another type of vehicle might be better. Has anyone done this or got any pictures of how they've fitted a snorkel?
John
Snorkels for Brumby
- Pommiebrat
Try this link. It is from a member on this forum. I cant remember which vehicle it come from. Maybe a forerunner .Easy way is , go to get one and try on brumby and see how it fits body line before purchase.
http://rides.webshots.com/album/555057146owdsAW
rtcb65
Redneck Rick.
Redneck Rick.
2" steel tube, no bends just cut and welded. This is what my mate knocked up for his. Took a couple of hours. He used a weber, 90mm elbow down pipe bit, flex tube from a industrial vacuum cleaner and a Liberty airbox.
Yeah there my pics. Snorkel is off a toyota hilux from memory... i would need to check... it's been a while.
Also for your information the front half of my car is exactly the same as a brumby so this will work the same way on your car.
Also refer to these links for more info.
showthread.php?t=3540&highlight=Snorkel
showthread.php?t=4163&highlight=Snorkel
Dave
Dave
