Need some help, I'm after some gaskets for the carbs. Just the ones between the top and the middle part. The other standard carb has something similar but not the same as the duals.
Anyone know a part number or where I could find one overseas?
Other wise I'll have to cut two out.
Also need those bottom gaskets/heat blocks or what every they are, but I think they are older EA81 standard and should be able to get them at the auto shop.
Dual carb gaskets
Dual carb gaskets
Cheers, I'll talk to my local parts guy monday about it with those numbers.
