Transfer Problems
dylan
Transfer Problems
Post by dylan » Sun Aug 17, 2008 2:36 pm
:confused:hi all,
having problems when going from 4x4 > 2wd in my L wagon. doesnt do it every time but most....
basically when i transefer back to 2wd the steering wheel goes spastic and ripps out of my hands and shakes and feels like major wheel imbalance for a while but then it goes away after a few minutes and all is fine??? any one had this happen?
(spoke to a mate and he was thinking maby the transfer case might not have oil and not shifting properly or something like that?)
if its not native its not cool.....
Battlewagon
Post by Battlewagon » Sun Aug 17, 2008 6:30 pm
Which gearbox do you have?
brumbyrunner
Post by brumbyrunner » Sun Aug 17, 2008 6:53 pm
Are all your tyres the same size?
Are your diff ratios the same?
Are you driving in a straight line when disengaging 4WD?
Your "transfer case" is part of the gearbox. Check the oil level on the dipstick. You want it about 10 or 15mm above the full mark but I bet that's not the problem.
Settlement Creek Racing
dylan
Post by dylan » Mon Aug 18, 2008 11:23 am
Battlewagon wrote:Which gearbox do you have?
i have a manual g/box
not sure about my ratios?, but yes to everything else.....
Post by AlpineRaven » Mon Aug 18, 2008 3:03 pm
are all 4 tyres the same? Has anyone replaced the diff or gearbox recently?
Post by El_Freddo » Mon Aug 18, 2008 10:31 pm
dylan wrote:any one had this happen?
Never heard of this happening after disengaging 4wd. If you're driving on a non-slippery surface in 4wd the steering will become very difficult and may pull from side to side as one wheel looses a bit of traction on the front end.
Sometimes is it hard to disengage 4wd due to binding of the 4wd system - each wheel works against eachother when driving on a hard surface particularly when driving around corners. This is normal.
dylan
Post by dylan » Tue Aug 19, 2008 11:23 am
all 4 tyers are teh same (only a few months old) and the gearbox or diff have not been replaced. did get a new clutch and timing belts done couple of months ago though.....
brumbyrunner
Post by brumbyrunner » Tue Aug 19, 2008 7:28 pm
I recommend taking your car to someone that knows old Subarus. Try Rising Son.
Post by AlpineRaven » Tue Aug 19, 2008 7:54 pm
Could be linkage that is wearing out and acting funny.. I suggest you to get it checked by someone who is familiar with Subarus specially gearboxes.
shuffbag
Post by shuffbag » Tue Aug 19, 2008 8:15 pm
yeah check your linkages, the nut holding the 4wd linkages on my L worked loose and fell off. macgyver'ed it back together problem fixed
dylan
Post by dylan » Wed Aug 20, 2008 10:28 am
yeh im going to rising sun on friday so ill see what they say...
