hi team,
obviosly having a few issues with my horse feeding brumby.
didnt pass rego because of an oil leak.
it is obviously coming from the rear output shaft that links into the gearstick linkages.
what is the miracle cure?
tell me it's just a case of taking the linkage off and pulling a rubber o ring off and replacing it with a new one?
thanks guys for the help
EA81 geabox output shaft leak?
- SUBIIE
- SUBIIE
thanks rsr legacy
thank god ther is an easy fix.
u guys rock
u guys rock
I replaced 3 gearbox seals on my L - had to take out the gearbox due to their design (the MY are different), $80 later I had the 3 seals that only subaru could get me...
Now the tranfer gear selector seal is leaking, 3 years down the track - its one that I didn't replace at the time...
