EJ inlet manifolds - 'plastic' or alloy ???
I was looking under the bonnet of a 98 Forester EJ20 and noted plastic inlet manifold
what is the go on these, on some models and not others?
- bobbyjimmy
Yes, they are plastic on some models and alloy on others
Another crazy thing from Subaru I'd say, perhaps weight saving, perhaps cheaper to manufacture, lets just hope they don't start making everything out of plastic or we will all be driving Hyundai's!
(does that meet the approval of whatever Nazi deleted my previous post?)
- FROG
yep keeps air cooler which is what we want hey
That's interesting, I guess they wouldn't hold as much heat as an alloy one. I've never thought about how the inlet manifold itself could be changed to drop air temperatures. Maybe in the future we will see manifolds with large, dense heatsink fins incorporated into the design to increase surface area and dissipate heat. I'm guessing the plastic manifolds probably haven't come out in turbo models as they may not cope with boost.
I've been looking into the newer 6cyl EZ30R motors at little (dreaming more like) and they have a plastic manifold.
- twilightprotege
I remember years ago one of the car magazines did an article on putting a spacer in between the manifold and the cylinder head to insulate it from heat transfer. You can usually find them in between the carb and manifold too.
actually it is recommended that you don't polish the ports as a slightly rough surface traps a film of air against it, which allows the air flowing into the engine to slide past it. A bit like the surface of a fighter jet...it's like sandpaper.El_Freddo wrote:Being plastic one would expect a smoother surface than the alloy cast would have = better air flow with less turbulance.
Better flow....
Problem is due chemicals, exposure & heat and will become brittle and crack... so thats downside about plastic.
Plastic intakes have been around for years...early 90s Dodge RAM's used them on the Chrysler small block V8 (LA, not G3 Hemi). I know of plenty with hundreds of thousands of km's on them with no issues of becoming brittle. There is also the advantage that the engine warms up much quicker than aluminium, so cold-weather idle time is reduced (better fuel economy / lower emissions).
Most carb spacers are made of phenonic, which is a hard light material that is also very easy to machine (we use it at work for making drill bit samples rather than use high-speed steel blanks). They are more often used to improve the flow of air between the carb and intake by increasing the length and thereby reducing the angle.
Dean.
Dean.
- bobbyjimmy
http://www.grimmspeed.com/catalog/index ... ceck8qka51dfoyl wrote: Most carb spacers are made of phenonic, which is a hard light material that is also very easy to machine
I've got a set on my EJ25 with alloy manifold.
After driving for 30mins +, the manifold, as you can imagine, is pretty hot, can't touch it with a bare hand.
With the spacers, its actually cool to touch even after driving 3 hrs +.
NOTE - if anyone gets these, you'll need gaskets (I got 4, top and bottom of spacer) and then you'll also need longer bolts (the one's that are supplies are about 8 - 10mm to short as he doesn't take the gaskets into account.
