Losing Coolant EJ22
iananita
Losing Coolant EJ22
Post by iananita » Tue Jul 22, 2008 2:50 pm
I'm losing coolant can not seem to find where. If the water pump is leaking, where does the coolant usually end up draining away?
If inside heater core, where does it usually drain away?
Post by AndrewT » Tue Jul 22, 2008 4:30 pm
Heater core you should have wet carpet and a noticeable smell of coolant inside the car.
Water pump it may be leaking out the timing covers and evaporating on the hot exhaust headers.
I would suggest running the car up to full temperature then going over it with a torch and checking everywhere for a leak.
Also, it's possible you have done a head gasket and coolant is leaking into the cylinders, is there are smoke or vapor coming out the exhaust?
BrennyV
Post by BrennyV » Tue Jul 22, 2008 5:27 pm
I also had a similar problem in my liberty and found it to be a mega airlock in the system that was causing it to push it out of the overflow and I Neva really noticed till I ran it up and checked for a airlock. I would suggest flushing the heater core also then slowing working coolant back into the system and be 100% you dont have a airlock.
Hunter S. Thompson
daveosubi
Post by daveosubi » Tue Jul 22, 2008 5:53 pm
Sorry to hijack but ive the same problem, loosing small amounts of coolant and no visible leaks. I did burst a heater hose a few weeks ago, so hopefully it's an airlock.
I reluctantly did check the oil and was happy to see it was still a golden black. But now after andrewt's responce im a bit worried again, I have noticed a bit of vapor from the exhaust, but it is near freezing this time of year in vic.
Is it a constant vapor to look out for? or does it go away like the normal cold start vapors after warming up?
And bennyv how'd you remove the airlock? I made sure I filled the radiator with the car facing up hill, and I park facing up hill to is that enough?
Cheers.
BrennyV
Post by BrennyV » Tue Jul 22, 2008 6:14 pm
Cheers.
I started by jacking up the front end slightly, then I removed the outlet hose from he heater core and started the engine wile poring in the coolant till it came out from the heater core then secured it again (wile engine was running) then let the system fill and get upto temp (with the cap off)
Hunter S. Thompson
iananita
Post by iananita » Tue Jul 22, 2008 9:27 pm
Surely with leaking head gasket, engine would be running like a hairy goat.
Air lock in heater core sounds good. There seems to be gurgling sound inside cabin once engine warmed.
Matatak
Post by Matatak » Tue Jul 22, 2008 9:28 pm
take to a workshop and get them to Pressure Test the system.
also make sure your Rad cap is good
If airlock in heatercore youd normally get a Gurgling/sucking kinda noise when at higher revs and load
edit - Headgaskets can go in many ways. sometimes not affecting engine performance at all
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by steptoe » Wed Jul 23, 2008 3:33 pm
mate had an EJ25 in shop few weeks ago. Customer had complained of a stumble on idle that disappeared on driving, then on a highway trip after successfully doing 450 km. it had gone to HOT on gauge. Car stopped and towed in. Pressure test of system showed nothing at cold temp. Heads off revealed head gasket gone only slightly. Different sort of gasket, metal with thin gasket 'paper' each side. Headman says it is common. There is not much between bore and water jacket on the deck.
FROG
Post by FROG » Wed Jul 23, 2008 3:42 pm
exactly....
like this post 10
showthread.php?t=8260&highlight=rotted
scroll down to the pic of my rotted block
SUBYDAZZ
Post by SUBYDAZZ » Thu Aug 07, 2008 11:31 am
If it's coming from the waterpump there will still be traces of coolant as it won't evaporate the salts etc. in the coolant, only the water.
If a pressure test cannot find the leak, try it with the engine running.
SUBYDAZZ
iananita
Post by iananita » Thu Aug 07, 2008 2:36 pm
I have an airlock like BrennyV says. Coolant overflows from fill tank. I need to flush thru and get rid of airlock in heater core. I have been trying to bleed air thru bleeder on side of radiator with some success. I only lose coolant after long trips with h'way speeds.
FROG
Post by FROG » Thu Aug 07, 2008 3:08 pm
get a gas check on your coolant its starting to sound the same as when my head gaskets went
iananita
Post by iananita » Tue Sep 23, 2008 2:14 pm
After trying all suggestions, pressure test normal, flushing heater core with hoses off, the only thing that worked was changing hoses over, why? I can not hear the heater core gurgling and not losing coolant. Thanks El Freddo
Post by El_Freddo » Tue Sep 23, 2008 9:14 pm
iananita wrote:Thanks El Freddo
No worries - you obviously did a search as I don't recall posting in here and can't see a past post of mine...
Subaru's work in mysterious ways, that's pretty much what I know that works every time.
iananita
Post by iananita » Wed Sep 24, 2008 2:10 pm
What is great about this forum, every one offers an opinion, not are all right not are all wrong, but there is always something there to help. Make sense?
El Freddo, you offered this advice in the thread L-series Cooling System Help
I thought it was a wacky idea at the time but had nothing to lose by trying it. By other posts it seems to be something that happens occassionally once air gets into the system. The radiator shop I got the pressure test done told me libertys + camrys can be a bugger to completely bleed, his suggestion raise front of vehicle hoses off and flush thru with town water from hose, defeats the purpose of coolant, but he sells + fixes corroded radiators.
