C.V cups and splines
- SubaRute
who out there knows,what liberty has a 22spline on the CV shaft,im looking for the right ball and case with a 22 spline and the cup to fit a liberty g/box,im told all lib g/boxs are 25 spline off the cup,please dont get
confused with the cup spline it the 22 ball and casing im chaseing where and what model subaru lib it comes from?
thanks leon
thanks leon
I've never heard of a liberty gearbox with a 22 spline cup, its typically 25 spline or 23 spline in the old L's AFAIK, but the rear diff should be a 23 spline cup in the early libs, up to what year I don't know I'm sorry.
If your after a front unit, the Carbie L series front shaft inner cups should do the job as they are all 22 spline on the cup, you 'll need to swap the shaft or the cage in the cup to make it fit. I'm not sure about which one to swap as I've never done it before.
Okay, making more sense now.SubaRute wrote:ok on the CV shaft i have,(MYshaft) has a 23 spline(not 22) so the cup spline for a lib g/box is 25.
what model liberty cup will fit my CV shaft?(MY,CV shaft)
another ej22 conversion,lib g/box and MY running gear
What you need is the Inner CV cups from an MPFI touring wagon. You should grab the cage too if not the whole shaft to play with. The Inner cup should fit the liberty cage without a problem. The spline count will be the same too, which is what your after.
Good luck
Talk to someone that specialies in drive shafts etc they can build any thing that you want in a shaft and have access to all the right information new front drive shafts new cvs both ends ej turbo gearbox standard to brumby outers only cost me $165 each with a warranty. I thought money well spent as he made sure they were balanced
as well.
as well.
So many optioins not enough time or money
23 spline on the shaft not the cup
u can use rx turbo inners on the shafts u got
there 25 spline on the cup
