Right headlight extremely dull.
- subarooster
heeya, The other day i hooked up spotlights and everything was sweet... but the next day, my right headlight is extremely dull. the power going to it is 0.70 volts on low beam and 10.00 volts on high beam.... Very strange indeed. Since this happened i have pulled out the spotlights and wiring but it is still dull. I have a bad feeling that i've killed something in my poor attept of wiring up spotties. Does anyone have an idea what has happened without actually seeing it? cheers, Tom
check ur fuses
Hunter S. Thompson
Hunter S. Thompson
- subarooster
not 100% its just happened to me before also when playing with spotties.
Hunter S. Thompson
Hunter S. Thompson
Could be a backfeed from the relay you had hooked up.
If you are still having probelms, i'll be out that way on the weekend so i'll have a look then
- subarooster
