Should I see flywheel thru housing EJ22
iananita
Post by iananita » Sun Jul 13, 2008 1:40 pm
Changed engine temp sensor yesterday. Noticed service hole thru housing of clutch under air inlet, should I be able to see the forward surface of the flywheel or should there be a rubber cover over this hole.
ej 22 flywheel.JPG (40.85 KiB) Viewed 1415 times
RedRoo89
Post by RedRoo89 » Sun Jul 13, 2008 2:14 pm
I don't believe that will be an issue unless you're planning on doing some serious mud-bogging. If not, no worries.
Matatak
Post by Matatak » Sun Jul 13, 2008 2:17 pm
yer theres usually a rubber bung there.
but by this time there hard as and dont stay in to well neways.
not a problem eitherway like Redroo says
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AlpineRaven » Sun Jul 13, 2008 3:09 pm
yeah thats for the timing light area - normally the rubber seal or cover has gone hard and either fallen off or mechanic forgot to put it back in, once I found one inside the gearbox! I am sure subaru will have new one there, mine is missing as well.
